Stage 1 advice
I read up on what's been posted lately and just have a few thoughts to add. First, as anyone can tell, there are many different ways to get a decent stage 1 done and not a single one of them is the ONLY way to do it. Other than that, just some miscellaneous things to add:
Air Cleaners - many available and they all get the job done. They are also very easy to install if you aren't afraid of a screwdriver and a wrench and most can be bought much cheaper online than in a store and you can really save on labor by installing it yourself. For example, I saw someone say they were quoted $149 for a Big Sucker kit. I bought mine for $120 online and installed it myself in 20 minutes.
The HD SE stage 1 download - personally, I don't think the download is enough for some applications, more specifically full pipes or very open baffled slipons like V&H's Straightshots. It has been suggested to compliment the download with IED's. I don't know a lot about them yet but, from what I've heard, that sounds like a reasonable combination and I'm hoping to find out more about these things from people that buy and try them out. As for the price of the download, I have a slight bone to pick about some things that have been said. As a Software Programmer, I have to add that, even though you can't touch the download, it is tangible in that it is software that is intellectual property and does have a cost associated with it. With that said, it has been my understanding for quite some time that dealers charge a flat fee of $150 for it and do not add for labor. If a dealer is adding labor to the quote, go to another one if you feel you need or want the download.
There has been a lot of useful information added to this thread. It can be very helpful to people but also VERY confusing. Suffice to say that to do a successful stage 1, you need a high flow air cleaner unit, not just a filter, and higher flowing pipes or mufflers. And you need to do SOMETHING to augment your A/F ratio be it downloads, fuel managers, tuners, IED's, or a combination.
i.e. on acceration and at flat-out top end, it increases your AFR and opens the rev limiter to around 6000 rpm whereas stock, your rev limiter kicks in around 4500 rpm. THEREFORE the IED's which will richen your AFR in closed loop mode ( talking O2 sensors here) are desirable at cruising and idle.
I agree the download is "intellectual property" but you can be sure, the programmer has been paid off by now by the MoCo and probably doesn't have royalties on each downoad, so the charge for a unit of download at $150.. is plenty, that's what i paid, and getting screwed for more is a rip-off.
BRAIN OVERLOAD!!!!!!!!!!!!!!
Man...I want to finish my Stage 1 (got the Rush 2.0 already) but I am so confused. I am not much of a gearhead myself so I was going to have the dealer do it but now I am afraid to even ask them for fear my wallet will be a grand lighter when I leave. When you guys started talking about IED's I started to wonder if I was suddenly in Iraq. After checking them out now I see I need a set of those as well so I can adjust the fuel mixture, a tuner, a SERT, acommander, a download, a dyno check, a new air filter......etc. It seems to never end. And being in California of course I can't even buy the fuelpak.
All I want is for my bike to run the way it should. Right now I am getting a lot of popping on decel and would like to get rid of it. The reason behind wanting to complete the stage 1 has nothing to do with the extra 5 or 7 hp or whatever. I want it because I want the bike to run the it really should. Not lean...just right. Not hot....but just right. Not popping...just a smooth throaty decel. Thats all I am asking for. Is that a whole lot?
ARGHHHHHHH
