Primary drain plug?
Old Apr 30, 2008 | 02:25 PM
speedjunkie's Avatar
speedjunkie
Default Primary drain plug?
Ok, I did a search in the Dyna and tech forum but didn't find what I'm looking for. I'm changing fluids in the bike and using the instructions in the owners manual, real book hasn't come yet. Anyway, for the primary drain plug, the instructions state 30-60in-lb for the torque. But, the diagram on the next page shows 14-21 ft-lb torque like the rest of the plugs. What gives? Which do I use? BTW, '07 Lowrider with the o-ring style plugs. Thanks for the help guys! Now, to get the damn derby cover screws out!!! [:@]
Mike
Old Apr 30, 2008 | 03:46 PM
dyna07custom's Avatar
dyna07custom
Default RE: Primary drain plug?
service man says 30-60" lbs
Old Apr 30, 2008 | 03:58 PM
Cornhusker's Avatar
Cornhusker
ORIGINAL: dyna07custom
I have an 07 Dyna Service manual and on pg. 1-26, it states:
4. Install drain plug back into primary chaincase cover.
Tighten plug to 14-21 ft-lbs (19.0-28.5 Nm).
Old Apr 30, 2008 | 04:09 PM
DougsDyna's Avatar
DougsDyna
Man am I glad I don't own a torque wrench!!!
DougJ
Old Apr 30, 2008 | 04:11 PM
Cornhusker's Avatar
Cornhusker
Personally, I'm partial to the 'gutentight' method!
Old Apr 30, 2008 | 06:13 PM
ezriderpgh's Avatar
ezriderpgh
14-21, i don't own a torque wrench, it's all in the wrist.
speedjunkie
Normally I'm ok with the "gootentite" myself. But I've got these high dollar Snap On torque wrenches just laying around BEGGING to be used! Thanks guys, I'll go put a little more on 'er!
Mike
Old Apr 30, 2008 | 06:40 PM
GaryInSanDiego's Avatar
GaryInSanDiego
I torque most everything I can find a spec for. If I didn't torque them, I'd tend to over-tighten everything, "just to be safe." You see lots of posts on various boards asking for help to remove stripped torx and allen bolts (sometimes it is because they used the wrong size bit). It takes a bit more time, but it's worth it. OTOH some folks have done it so many times, they have a built-in biological torque wrench.
Old Apr 30, 2008 | 08:38 PM
sargek's Avatar
sargek
For all my drain plugs and cover screws, I use my "bio-wrench", but for important stuff like axle nuts, fork pinch bolts, etc, I use the torque wrench. Probably should use the wrench for everything, but I currently only have a big a$$ 1/2 inch drive wrench. Need to get an inch pound one.
Old Apr 30, 2008 | 08:43 PM
06dynablack's Avatar
06dynablack
drain plugs just screw in till seated then just a good tap on ratchet handle does it for me no need for a trque wrench
Tricon
Jul 30, 2015 07:48 AM
br549A1
EVO
Apr 5, 2014 04:40 PM
Matrix
Feb 17, 2014 07:41 PM
blainem
19
May 30, 2007 04:29 PM
bancquo
25
Jan 24, 2006 02:11 PM
