Dragging pipes?
Old May 5, 2008 | 10:13 PM
tnelsmn's Avatar
tnelsmn
Default Dragging pipes?
I have a 08 Wide Glide and have almost ground off the mounting bolts on the lower pipe. I am asking those of you with aftermarket pipes if you have this problem? Specificly those of you with vh big radius, I am planning on these in the next month, do you drag any part of the pipes? Or are the pipes high enough to avoid this? Thanks for you help.
Old May 5, 2008 | 10:17 PM
joe.1955's Avatar
joe.1955
Default RE: Dragging pipes?
I also have an '08 Wide Glide, but with V&H Big Shots Staggered. The only thing I've scraped is the heel rests on my Kuryakyn pegs.
My brother has an '06 Deuce and has ground over 1/2" off the ends ofhis Big Radius pipes.
Old May 5, 2008 | 10:26 PM
tnelsmn's Avatar
tnelsmn
Yeah I am not to excited about scrapping up the 700$ pipes. But I am not a huge fan of the scalloped tips, so if I hit them a lot I could just cut them straight off, but would much rather just leave them alone.
Old May 5, 2008 | 11:20 PM
fj4069's Avatar
fj4069
if you grinf the stock pipes you'll grind the aftermarket ones. the penalty to pay for having such a good handling bike.
Old May 6, 2008 | 05:40 AM
UH60Hwkdrvr's Avatar
UH60Hwkdrvr
I touched down on the right side a few times shortly after I received my new Low Rider. I had previously been riding a Yamaha R1 Sport Bike. I just figured that I had to learn how to ride this new bike without grinding hard parts. Try slowing down a bit and not leaning as far. Touch down too hard and you could lever the rear tire off the ground. Not good, in my opinion.
m.a.c.
Old May 6, 2008 | 06:08 AM
petefwa's Avatar
petefwa
I dunno which one one have the most ground clearance, FXD, lowrider or an FDWG. I do know that when the exhaust clamp bolt on my FXD digs in itlifts the back wheel off the ground. It also leaves scratch marks on the bottom of my very expensive S&S pipes (I got ripped off big time when I bought those). I'd say even more expensive Big Radius pipes will suffer pretty much the same fate. If it's any consolation you do reach a point where you dont scrape anything anymore.
Old May 6, 2008 | 02:13 PM
compgeek789's Avatar
compgeek789
I have the V&H Big Radius pipes on my '07 bob and scrape the lower pipe all the time. I believe my Street Bob has the same ground clearance and lean angle as the Low Rider. Not sure about your lean angles for the '08 WG.
I scrape the foot peg first, of course, but adding a little bit more lean will start dragging the heat shield on the lower pipe. My first pic shows the lower pipe's route. It's quite a bit lower than the stock pipe route.
I love my bike and I really like the BR pipes. My only complaint with the BRs is the ground clearance on the right side. When I'm in a tight right-hand turn, though, I'm faced with making a simple choice:
A) Lean far enough to complete the turn safely and possibly scrape the lower pipe as a result.
B) Don't lean far enough and end up in oncoming traffic or ride off the road.
I don't like option B.
It's almost time to replace my foot pegs. Not much metal left on the underside before I scrape the bolt.
I've scraped the primary on left turns once or twice, too. The primary scrapes bother me a helluva lot more than heat shields.
I just live with the heat shield scrapes. I try to keep the marks clean so they don't rust. I'll have to replace the shield eventually. When it gets to that point I might shop around for a new set of pipes with better ground clearance.
[IMG]local://upfiles/27035/9E32B3498533404AAF0AFF76C01FB1A5.jpg[/IMG]
[IMG]local://upfiles/27035/2AAF8D85E4A04A11AEAACD53757AA1BE.jpg[/IMG]
Old May 6, 2008 | 02:54 PM
Airborne350G's Avatar
Airborne350G
I scraped my right foot peg a little but not the Big shot staggereds...
Old May 6, 2008 | 07:55 PM
tnelsmn's Avatar
tnelsmn
Thanks for the replies. I want to be able to lean the bike that far over, the first time I did it I didn't think I was that far down. Now I kind of think it's fun to be able to hit them, but don't want to ruin the new pipes when I get them. Maybe I need to fab something up like the ground feelers on the pegs of my buddy's Nightster.
Anyone with a Wide Glide and the Big Radius?
Thats a long way over to get the primary!
Old May 6, 2008 | 10:35 PM
meveratt's Avatar
meveratt
Have you checked your rear shock preload? I used to scrape my pipes doing righthanders all the time -- I'm not a light guy (230 pounds) and I found my shock preload was set at the softest. I set it two clicks higher, and now I don't scrape. I don't notice any difference in ride comfort either.
