shifting
Old May 8, 2008 | 10:34 AM
wescoot2's Avatar
wescoot2
Default RE: shifting
ORIGINAL: dyna07custom
prob not letting shift arm all the way down happens when I have a certain pair of boots on that are a little bigger have to concentrate on letting shift return
That makes sense to me, that would account why when I'm speed shifting it happens more often......can you say.....to quick on the trigger......LOL
Respects,
Ed
Old May 8, 2008 | 03:36 PM
dhoward's Avatar
dhoward
Not normal.
Have it looked at.
Old May 8, 2008 | 07:51 PM
jeffbcn's Avatar
jeffbcn
Nothing like that on mine. I wonder if lubrication is the culprit. What are you running?
Old May 8, 2008 | 08:05 PM
06dynablack's Avatar
06dynablack
I am using the formula+ stuff.It has happened in 35000 miles maybe half dozen times generally it was winding her up when it happens .either the linkage or pressure on it maybe.
Old May 8, 2008 | 08:09 PM
Razzdad's Avatar
Razzdad
Most likely operator related. Try slowing down your shifting. Lift the shifter and hold it up while you let the clutch out. Then be shure that you are letting the shifter return completly and not holding it up a little between shifts. If it still acts up bring it to the dealer for adjustment.
Joe
Old May 8, 2008 | 08:18 PM
sargek's Avatar
sargek
Sort of happens to me too - every once in a while it will almost grind, but then I notice I didn't pull the clutch all the way in and/or shifted too fast. If I make deliberate clutch pulls and shifts, it works as advertised about 99% of the time. You figured I'd have learned to shift after 30 years in the saddle...it's those early days on motorcross bikes that did it - yeah, yeah, that's the ticket!
Old May 8, 2008 | 09:17 PM
06dynablack
ORIGINAL: Razzdad
Joe
yeah guess i dont know how to shift a hd after 225000 miles
Old May 9, 2008 | 07:13 AM
Razzdad's Avatar
Razzdad
06dynablack Date 5/8/2008 7:17:19 PM
quote:
ORIGINAL: Razzdad
Joe
My reply was for durwood but if my advice helps, you're welcome.
Old May 9, 2008 | 07:33 AM
first dyna 07's Avatar
first dyna 07
07 super glide Dyna thank god no problems 3900 miles . Get it cheked
Old May 9, 2008 | 10:13 AM
SK8ROD's Avatar
SK8ROD
quite normal, its called a "false neutral" and affetcts most sequential boxes. So dont panic about it
pete
