ANy one use this ?
Old May 9, 2008 | 08:22 AM
LeadSlinger0311's Avatar
LeadSlinger0311
Default ANy one use this ?
This is not anothor what should i use post . I repeat this is not what should i use post !
just want to know if any of you have tried this or not ?
buddy runs it and i will be damned it really helps quite the tran down .
but just wanted some feed back from others .
I know all about redline , amsoil,mobil 1 and so on . so we dont need to turn it into a i like this and that thread .
thanks for any info http://www.autozone.com/R,NONAPP3587...ductDetail.htm
[*]Lucas 85/140 Plus Gear Oil is a technical blend of oils and additives designed to give longer oil life and longer component life with less power draw.[*]This product is ideal for older gear boxes.[*]This formula slows or stops all oil leaks and cushions gears to reduce lash in worn gear sets.[*]It resists breakdown from contact with water and will blend with other gear oils, even synthetics.[*]This product exceeds all GL classifications.
Old May 9, 2008 | 08:45 AM
LeadSlinger0311
Default RE: ANy one use this ?(disreguard)
Never mind
if my dumb A$$ could spell Lucas insted of lucus the search function would have worked got the answers i was looking for .
later
Slinger
Old May 9, 2008 | 05:12 PM
Righteous's Avatar
Righteous
Been there done that my friend
druminitup
13
Dec 1, 2013 04:49 AM
Shaylex
EVO
Sep 30, 2013 11:02 AM
Rynb15
Oil Archive (no new posts)
Feb 25, 2012 07:31 AM
HDV-GLIDE
Aug 21, 2008 08:23 PM
wrencher
Apr 5, 2008 09:17 AM
