help with tank lift hitting trees
Old 05-17-2008 | 02:55 PM
wiegs's Avatar
wiegs
Default help with tank lift hitting trees
Hi, I installed a 2" tank lift and the clamp bolt on the upper tree on the left side of my bike is hitting the tank. It has actually chipped the paint. Any suggestions to remedy this? I was thinking of installing a upper longer bolt on the tank lift and putting an acorn nut on the end. That way the tree will hit the bolt before the tank.
Old 05-17-2008 | 03:25 PM
ezriderpgh's Avatar
ezriderpgh
Default RE: help with tank lift hitting trees
What I have seen on here that people do in this situation is, they remove the rear tank bolt and ream the hole oblong towards the front of the bike, you can use a dremel or file, this allows the tank to be moved back farther giving clearence needed.
Old 05-17-2008 | 04:14 PM
rounder's Avatar
rounder
you should have some room to pull back the tank then tighten without reaming the hole... try that first!
Old 05-17-2008 | 05:07 PM
Gwjvw's Avatar
Gwjvw
i would like a 2in tl on my dyna but i think my blinkers might hit and i dont want to move a million things just to put on a tank lift, but i like them alot!
Old 05-17-2008 | 05:29 PM
Shrug's Avatar
Shrug
+1 EZRIDERPGH
Takes only a few minutes to elongate the rear tank bolt hole about 1/8". Problem solved. Coolness abounds.
Old 05-17-2008 | 06:35 PM
wiegs's Avatar
wiegs
I decided to go without the lift. I tried to move the tank back but it was already all the way. First, my blinkers were hitting the tank. I fixed that. The the throtle cable was rubing the top of the tank. I really don't want that scratching my tank.
Old 05-17-2008 | 06:47 PM
Gwjvw's Avatar
Gwjvw
Did you relocate your blinkers?
Old 05-17-2008 | 06:54 PM
wiegs's Avatar
wiegs
I just pointed the blinker more upwards and that did the trick.
DenimBlackFLHXS
2014-2023 Touring Models
05-15-2014 11:30 PM
DitosDad
07-11-2012 02:42 PM
70mach1
09-08-2008 12:44 PM
BONES206
11-04-2007 08:52 AM
cstolp
06-17-2007 03:31 PM
Quick Reply: help with tank lift hitting trees
