Question for those running a windshield
Old May 18, 2008 | 03:01 PM
dizzy1450's Avatar
dizzy1450
Default Question for those running a windshield
I just got a standard height HD quick detach windshield for my bob. I've done about 150 miles with it and it does the job. The only problem I have with it is that I can't get used to looking through it. Am I supposed to look through it? or over it? It's too tall for me to look over. So if I'm doing some twisties I feel like the windshield is getting in the way of my vision. It distracts me from looking "through" turns. Anyway, if anyone can shed some light on this issue for me I would appreciate it. This is the first time I've ridden a bike with a windshield.
Old May 18, 2008 | 03:09 PM
2002flstc's Avatar
2002flstc
Default RE: Question for those running a windshield
I'm sure you will get both answers, over and through...
I have two bikes, one I look over it my '94 softail the other I look through it my '02 softail...
My two cents, you will get used to it either way...
Don51's Avatar
Don51
dizzy
I have mine set up so I look over it just for the reason you stated. The only thing I can think of to do with yours is to dremel the top to get it to the height you would need to look over it. Sorry, not much help!!
Old May 18, 2008 | 03:13 PM
l.ray's Avatar
l.ray
you will get used to it& it's DETACHABLE!!!!!![sm=closed.gif][sm=biker2.gif][sm=bling.gif]
Old May 18, 2008 | 03:18 PM
wescoot2's Avatar
wescoot2
Look over it.....cut it down if necessary.
Ed
Old May 18, 2008 | 03:22 PM
cwalms's Avatar
cwalms
you'll get used to it either way.
Old May 18, 2008 | 03:34 PM
joe.1955's Avatar
joe.1955
ORIGINAL: wescoot2
Ed
+1. Get it cut down, if you ride through fog or rain you won't be able to see.
Old May 18, 2008 | 03:42 PM
coastrider's Avatar
coastrider
I had the same problem when I first put mine on my 06 bob. I now have it set so I look over it almost all the time. The bottom bracket is about 1/2" above the bottom tree. It was all the way down but I installed a set of Kury bullet lights and had tomove it up enought to clear the lights. If you can't adjust it to suit you it can always be cut. Good luck.
Ride Safe.
Old May 18, 2008 | 03:48 PM
olddude48's Avatar
olddude48
Another vote for look over it! Have it cut down.
[align=left] [/align]
Old May 18, 2008 | 05:00 PM
maddghost's Avatar
maddghost
The ideal spot is to have the WS come just up to your nose. myFatbob has the mid detatchable and it could have been maybe an inch higher,however between 65 and 70 mph it just feels like a slight breeze,but no heavy wind pushing mr bsck.I think it's perfect.
