Panacea Tailight
Old May 20, 2008 | 12:48 PM
05Fatty's Avatar
05Fatty
Default Panacea Tailight
Instead of relocating the turn signals I'm going to get rid of them and use the Panacea tailight. Based on the instructions it looks easy to install but I wanted to see if anyone had any tips. Is the plug in for the load equalizer etc... right under the seat?
Old May 20, 2008 | 01:38 PM
Punty's Avatar
Punty
Default RE: Panacea Tailight
Yeah it really isthat easy
Old May 20, 2008 | 03:28 PM
ShoreRider's Avatar
ShoreRider
I haven't installed mine yet, just got it last week and been riding too much. Though the instructions look easy enough. Will post any tips once I get them installed if I haveany.
Old May 20, 2008 | 04:07 PM
doulos's Avatar
doulos
it is very simple. shouldn't take more than 20 minutes. my only recommendation would be to remove the battery and battery compartment for easier access to the wiring harness.
Old May 20, 2008 | 10:00 PM
pwer pla's Avatar
pwer pla
20 min job, super easy, I accesed wiring harness from under the seat and didn't have to take out the battery or battery box, attached a pic to show you what mine lookes like also bought a couple of emblems from HD to cover the ts holes fit perfectly. Good luck
[IMG]local://upfiles/43099/E61063F246184257978E425A9C83EF93.jpg[/IMG]
[IMG]local://upfiles/43099/82D98CE27A6044CBBA343192505319FD.jpg[/IMG]
Old May 22, 2008 | 07:10 AM
05Fatty's Avatar
05Fatty
Thanks! Mines on order from Zanotti so I should have it soon.
Old May 22, 2008 | 09:04 AM
blacked out's Avatar
blacked out
so the Kury panacea light will allow you to get rid of the rear turn sigs ? Is this the one you guys are talking about ?
http://www.kuryakyn.com/products.asp...ey&ci=3007
Old May 22, 2008 | 11:22 AM
blacked out
bump
Old May 22, 2008 | 12:56 PM
Mike1433's Avatar
Mike1433
It is a very simple install, but when they say don't use the hazards with the load equalizer they mean it. Hit mine accidentally then smelled burning electronics. Nothing in the blinker system worked right after that until I removed the load equalizer.
Blacked Out, that is the light I used. Only issue I see is it gets a lot of moisture in the unit.
Old May 22, 2008 | 01:06 PM
JakeInMa's Avatar
JakeInMa
Here is some pics of the Panacea, along with Alloy Art Strut Lights. I also have the Progressive Suspension Shock Lights, I just don't have a pic of them installed.
