Popping on Decel - Need advice
Old May 20, 2008 | 07:25 PM
Rattbone's Avatar
Rattbone
Default Popping on Decel - Need advice
When is popping considered a problem? I have an 08 Fat Bob with Rush 1.75 slip-ons, big sucker a/c and PC III programed from Fuelmoto. I'm having occational popping on decel from 1st and 2nd gears from high rpms. My buddy also noticed black smoke from my pipes when I hammer down. I've only put 210 kms on it so far and everything seems to run really well (i.e. no hesitation, etc). Do you guys think I need to adjust the PC III or does everything appear to be normal?
-Ratt
Old May 21, 2008 | 02:15 AM
SK8ROD's Avatar
SK8ROD
Default RE: Popping on Decel - Need advice
Jamie tends to set up on the rich side, you can email him for a leaner map, in fact i think you have to call at the moment because his website map facility is not working
Old May 21, 2008 | 06:35 AM
Rattbone's Avatar
Rattbone
Do you think I need a leaner map or should I continue to run as is. For example, I went for a 10 km ride last night and there was no popping.
xbox
Jul 7, 2009 08:17 PM
HDnAQHA
Nov 21, 2008 11:36 PM
SC-Longhair
Sep 7, 2008 10:22 AM
Darksyde
Apr 30, 2008 08:51 PM
stagolee
Apr 18, 2008 07:46 PM
