big sucker I or II?
Old May 28, 2008 | 07:31 AM
Pearles's Avatar
Pearles
Default big sucker I or II?
What do most A/N Big Sucker owners have stage I or stage II? I'm going to order one tonight, but not sure what direction to go with on my superglide. I see stage II will get 20% more, but are there any requirements for stage II? Thanks for the help!
Old May 28, 2008 | 07:34 AM
grandpawmoses's Avatar
grandpawmoses
Default RE: big sucker I or II?
the stage II is physically larger and might hit your leg. The stock cover wil not fit either.
GPM
Old May 28, 2008 | 07:35 AM
2007fxdc's Avatar
2007fxdc
Stage 1 here. If you are doing a stage 1, then that is all you need. Using anything that brings more air in that is not needed is only going to lean the bike out even more. If the engine hasn't been upgraded (biggerdisplacement)to need the additional air, why push it through there? Stage 1 is for a stage 1 upgrade, stage 2 is for a stage 2 upgrade, pretty simple.
Old May 28, 2008 | 12:36 PM
SK8ROD's Avatar
SK8ROD
agrred,, but even more than that i have read on here somewhere that the stage 1 BS flows enough for 103 + cams etc.. either way, i would go stage 1 they look better
Old May 30, 2008 | 06:50 AM
Dooley's Avatar
Dooley
I had one one my Sportster, stage 1 flow PLENTY of air.
Stage 2 was a bit too big, I had to bend my knee around it.
I noticed no performance difference between the two.
Old May 30, 2008 | 08:12 AM
Marksman's Avatar
Marksman
Ordered the Stage 1 today. I'm sure it is more than enough airflow.
I also want to use the round "Born to Ride" cover off the football and have an open filter. I love that look.
Aylor70
Nov 15, 2012 07:57 AM
Avalanche_Mutt
Apr 8, 2010 02:56 PM
shrini23
Oct 5, 2009 01:44 PM
anubisss
Jul 1, 2009 01:01 PM
mountian man
Oct 29, 2007 11:29 PM
