Wheel spacers
Old May 31, 2008 | 05:04 PM
Nach's Avatar
Nach
Default Wheel spacers
Hey guys, pretty sure that it doesnt matter but Im putting my front wheel back on and did not pay any attention to how the spacers came off and the book says to make sure they are installed correctly. Does it matter how the spacers go on? The both look the same to me?
Old May 31, 2008 | 05:20 PM
ken10652's Avatar
ken10652
Default RE: Wheel spacers
If your book states a process you should follow it. As an engineer I have never gone to the trouble of insisting on a process of assembly out of whim. Good luck and be safe
Old May 31, 2008 | 05:23 PM
Nach's Avatar
Nach
As an engineer I dont either thats the reason for the thread...Im sure they didnt put it in there for nothing
Old May 31, 2008 | 05:41 PM
Nach's Avatar
Nach
Ok, just realized my caliper is screwed up giving me incorrect measurment. One spacer is longer than the other. I think the longer one goes on my brake side. Can ayone confirm this?
( 2006 superglide)
Old May 31, 2008 | 05:47 PM
Nach's Avatar
Nach
can someone go out and take a quick look at their bike, on of the spacers has a little v notch on it.
Old May 31, 2008 | 06:05 PM
retiznapuerco's Avatar
retiznapuerco
Hope this helps, I just went outside to take a look, on my Wideglide 2003, short spacer is on the brake side, long one on the other side.
Cheers,
Old May 31, 2008 | 06:09 PM
Nach's Avatar
Nach
Thanks for taking a look man, Im thinking thats the way it goes as well but Im hopeing someone on here has a 06 to make me feel better before I take off and something crazy happens.
Old Jun 1, 2008 | 07:07 AM
HarleypsychRN's Avatar
HarleypsychRN
Seems like it'll only go one way. The rotor has to fit in the caliper. The wheel should be in the middle of the folks. If the spacers are the same then theoretically they're interchangable. If not switch them until it's right and if you still need peice of mind next time you're at the Stealership ask them to take a look at it for you. Maybe that's an oversimplication (I'm not an engineer). You can always buy a service manual (a good investment anyway) as a double check. Maybe some of 06' owners will post a pic for you.
Old Jun 1, 2008 | 10:24 AM
Nach's Avatar
Nach
HarleypsychRN, I ended up with the long one on the brake side. Im sure your right I was probably overcomplecating it, just wanted to make sure. I have the manual but it didnt help alot in this case, or if it has the info I havent found it yet. Thanks for the help
Motorhate
Jan 25, 2018 11:21 AM
jqb12
Wheels/Tires
Mar 28, 2017 04:42 PM
Falcon195
Jun 4, 2015 09:46 PM
texashillcountry
EVO
20
Feb 11, 2015 03:12 PM
VenturaChop
Jun 22, 2008 11:18 AM
