I am getting my Thundermax installed!
Old Jun 3, 2008 | 09:09 AM
erictolsma's Avatar
erictolsma
6th Gear
Default I am getting my Thundermax installed!
My streetbob is now at the tuner, getting a closed loop Thundermax installed. On friday I ride to the Belgium Ardennes (200 mls) for the Annual Benelux Rally. I can't wait to feel the difference.
I have a 2006, with high flow airfilter and SE slipons. The bike runs OK, but very hot and pops on decel. Hope this is gone by friday.
Any tips on how to ride to get the system calibrated quickly?
Old Jun 3, 2008 | 09:25 AM
ColoSpgsMark's Avatar
ColoSpgsMark
Default RE: I am getting my Thundermax installed!
Exercise as many RPM/throttle positions as you can. Also, as it will only adjust a given percentage each engine-on cycle, you may want to take a few short runs to get some cycles.
Good luck and have a great trip!
Mark
Old Jun 3, 2008 | 10:13 AM
mcouture's Avatar
mcouture
Yup, by default it adjusts a maximum of 5% per engine start/stop sequence. So a few short rides at first to get things settled in, then just ride and smile!
By the time you have a couple/few hundred miles on it you should be pretty close to perfect.
Old Jun 4, 2008 | 05:52 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Be sure and lets us know how it goes.
Old Jun 4, 2008 | 06:01 AM
first dyna 07's Avatar
first dyna 07
Hey good luck with it , and be safe with the newly found horse power . Then let it rip , I found a little more power by installing enriching wires from nightrider.com they say it gives you 5 more horsesfine for me.
Old Jun 4, 2008 | 06:16 AM
LownBlue's Avatar
LownBlue
You will love it. It really woke my bike up and I haven't heard a single pop on decel since it was installed. Mine seemed to have calibrated itself after 3 short rides. Have a great time at the rally.
Old Jun 4, 2008 | 09:26 AM
Airborne350G's Avatar
Airborne350G
I heard that you need to do some cutting to get the brains of the system to fit in the location the stock ECM. Can you confirm this and if so how much cutting is required?
Old Jun 4, 2008 | 09:37 AM
HOGRIDA_06's Avatar
HOGRIDA_06
ORIGINAL: Airborne350G
A little trimming of the electrical caddy is required. It took me about 5 mins. with a roto zip. The only problem I had were the brass fittings that screw the ECM in to the caddy. I had one strip out, so I ended up drilling it and just using a nut and bolt.
Old Jun 4, 2008 | 09:53 AM
Airborne350G
ORIGINAL: HOGRIDA_06
Thanx for the info. You didn't happen to take an pictures of the area you had to cut? Took me awhile just to cut the wires to the original turnsignals on the handle bars when I moved them to the forks. I didn't want to go through the hassle to pull the wires out of the bars.
Old Jun 4, 2008 | 12:48 PM
HOGRIDA_06's Avatar
HOGRIDA_06
I didn't take any pictures, but they show a pic. in the manual of how much and where to cut. Don't let cutting the caddy keep you from the Tmax, it truely is easy to install.
