Need expert help upgrading my engine
Old Jun 5, 2008 | 08:26 AM
Rebel78's Avatar
Rebel78
Default Need expert help upgrading my engine
I was going through SE catalog searching for REAL performance upgrades, but I got confused &amp\\; lost!! Dont know what to go for after finding many options for my 2007 Dyna!
&nbsp\\;
I'm looking for a kit that can offer good low-mid range pull, this is what I found:
&nbsp\\;
1- 103 stage 1 kit
2- 103 stage 2 kit
3- 110 stage 1 kit
4- 103 SE Pro stage 2 kit (high output)
5- 103 with 50MM EFI &amp\\; ported HTCC heads
&nbsp\\;
I'm leaning toward number 3, with the following configuration:
&nbsp\\;
Big bore cylinders, Twin Cam performance&nbsp\\;heads, flat top stroker pistons&nbsp\\;&amp\\; SE-258 cam
&nbsp\\;
&nbsp\\;
Any feedback or opinion will be helpful.
Old Jun 5, 2008 | 08:36 AM
Rebel78's Avatar
Rebel78
Default RE: Need expert help upgrading my engine
This is a link to SE website, you will have to download the PDF catalog
&nbsp\\;
http://www.harley-davidson.com/wcm/Content/Pages/Racing/screamin_eagle_parts.jsp?locale=en_US&amp\\;bmLoca le=en_US&amp\\;HDCWPSession=hj1JLHpPzLBLXBztyR0nkv Y9XZ48zF6TlNJQZTqYLJcbVmVlRzxh!-1074051880!-653284669
Old Jun 5, 2008 | 03:19 PM
Rebel78's Avatar
Rebel78
Or should I go for the 107 big bore kit from revolution performance?
Old Jun 5, 2008 | 08:44 PM
tomato's Avatar
tomato
What are you after?&nbsp\\; All out speed and power at any cost?&nbsp\\; If so, aftermaket stuff will get you there cheaper.&nbsp\\; However, if you want power and durability, I would stick with Screamin' Eagle, as you will still have a warranty.&nbsp\\; SE compression ratios and cam lifts tend to be lower than aftermarket.&nbsp\\; The trade-off is, of course, power...
Old Jun 7, 2008 | 01:36 AM
Rebel78's Avatar
Rebel78
Cost is not a problem, I just wanna go right from the first time, dont want to waste time &amp\\; money trying different configurations.
Old Jun 7, 2008 | 08:53 AM
mentor70's Avatar
mentor70
IF cost is no problem then U need to call Kevin at Head-Quarters USA or Hillside cycle or GMR and forget about the SE parts all together!
&nbsp\\;
HQ has 103 and 107 kits avaible that will give you 120+ lbs of torque and are Very reliable. These are not Race engines, just very hot touring motors that have a real big kick in the pants.
&nbsp\\;
Philm on the touring section just pulled 157 lbs of torque from his HQ 120 and just returned from a 3000 mile trip that he was averaging 45 mpg!
masterblaster
Aug 7, 2008 06:58 AM
07fxdwg
Jul 7, 2008 12:34 PM
2006ultra
Jun 29, 2008 10:44 AM
99Sportster
Jun 28, 2008 04:37 PM
Rebel78
Jun 18, 2008 08:14 PM
