Help! Engine Code p0562 Low Voltage
Old Jun 7, 2008 | 09:47 PM
StreetSalvation's Avatar
StreetSalvation
Default Help! Engine Code p0562 Low Voltage
I was stranded on monday after a check engine light came on. I figured it might just be my two year old battery. I bought a new one, and low and behold, I was stranded again today!&nbsp\\;I am trying to&nbsp\\;figure out why&nbsp\\;there is low voltage, or a constant drain on the bike.
&nbsp\\;
My bike just had the primary case bearing replaced by the dealer. The warrenty is up, and the dealer is 100+ miles away. Dealer is not an option. I was hoping someone has some experience with this issue. Please help.
Thanks!
Street
Old Jun 7, 2008 | 09:57 PM
BluBob's Avatar
BluBob
Default RE: Help! Engine Code p0562
I have a copy of a code list off of this forum that shows P0562=Battery Voltage Low EFI.&nbsp\\; Does that help?&nbsp\\; Try a search on the forum for that code for more info.&nbsp\\; Good luck!
Old Jun 7, 2008 | 10:02 PM
StreetSalvation
I do know the code pops up as low voltage. Thank you Bob for that, but I am trying to figure out why it is causing the low voltage. Any insight?
&nbsp\\;
&nbsp\\;
Thanks
&nbsp\\;
Street
Old Jun 7, 2008 | 10:17 PM
BluBob's Avatar
BluBob
I sold batteries for a couple of years and I installed more than a few that turned out to be bad from the factory.&nbsp\\; Can you check the code on the battery to see when it was made?&nbsp\\; Other than that and the connections, I don't know.
Old Jun 8, 2008 | 09:40 AM
jbond's Avatar
jbond
5th Gear
Default RE: Help! Engine Code p0562 Low Voltage
You might check your voltage regulator connections..
Old Jun 8, 2008 | 09:49 AM
joe.1955's Avatar
joe.1955
+1.
&nbsp\\;\\\\\\;
Did you just buy a new battery, or did you have the charging system checked? I have had voltage regulators go bad in a couple of years.
&nbsp\\;\\\\\\;
Charge the battery then check the voltage at the battery, should be 13.2 volts.&nbsp\\;\\\\\\;With the engine running, you should get 14+ volts.
&nbsp\\;\\\\\\;
You may also want to check the engine ground to make sure it is tight. If you don't have a multimeter, you can get them cheap at any auto parts store.
p.o_o.h
Jul 21, 2009 07:58 AM
pococj
Jul 8, 2009 05:33 PM
deleontow
Jul 12, 2008 10:37 AM
hammon
Jun 9, 2008 06:53 PM
ultra2006
Feb 26, 2007 04:38 PM
