i'm thinking of saving money and doing a 5000ml service myself,is it just an oil and plug change or is there more involved??any help greatly appreciated
cheers
mick
If you plan on doing your own service work, take some of the money you save and purchase a service manual.
Here is what is scheduled for the 1000 service:
[ul][*]Replace engine oil and filter[*]Inspect brake lines for leaks[*]Inspect air cleaner[*]Tire pressure[*]Wheel spoke tightness[*]Replace primary lubricant[*]Replace transmission lubricant[*]Check clutch adjustment[*]Inspect rear belt and sprocket, adjust[*]Check, adjust, and lube throttle, brake and clutch cables[*]Check brake fluid level and condition[*]Inspect brake discs and pads[*]Inspect spark plugs[*]Check operation of electrical equipment[*]Check adjustment of engine idle speed[*]Adjust sterring head bearings[*]Check critical fastener tightness[*]Inspect and lubricate jiffy stand[*]Verify system and component functions during road test.[/ul]
and more work to be done on the 5,000 mile service you inquired about. \\; None hard though. \\; The schedule should be in your Owners Manual and How to do it in the Service manual.
Sorry, posted the info for 1000 and meant to offer 5000. \\; The 5000 service is the same as I listed above except they do not list critical fastner check, steering head bearing adjustment, nor the critical fastner inspection. \\; Everything else listed is done.
Hello no need for primary lubricant &\\; transmission lubricant change.But i did them just to put fresh oil in there.It's a very easy service.No need to pay all that money for something you can do yourself.I think it's about £250 here in the UK about $500.
