Help
Old Jun 9, 2008 | 08:38 AM
iaov's Avatar
iaov
Stage II
Default Help
Hi everyone. I have an 06 Street Bob. Coming home the other day the battery and fuel pump light came on. Bike ran fine for 2 miles to get home. Checked with a DVM and deffinately no charging going on. My question is about the fuel pump indicator light coming on. Is this because the battery is not being charged. When I turn on the bike the pump and light come on for a few seconds and then go off as normal but if I start the bike the pump indicator comes right back on. Also what is the output voltage of the stator supposed to be?
Old Jun 9, 2008 | 08:47 AM
JRK5892's Avatar
JRK5892
Default RE: Help
that is your check engine light not the fuel pump light... you can run a diagnotic on the system and it will give you the codes of what is wrong... that light could mean anything from injectors to chargin to lights issues... i do not have the how to or the code meanings at this PC but if someone does not chime in with a how to on triggering the computer in the bike to give up the codes let me know and i will dig it up when i get home... ooh ya 12v is the answer for the stator ? as well
Old Jun 9, 2008 | 10:23 AM
iaov's Avatar
iaov
Stage II
Default RE: Help
Thanx Joe. Hopefully its on because the reg is dead. I'll check tonight. Thanx again for the info.
Old Jun 9, 2008 | 11:27 AM
BluBob's Avatar
BluBob
Default RE: Help
https://www.hdforums.com/m_2039863/tm.htm
Old Jun 9, 2008 | 11:34 AM
JRK5892's Avatar
JRK5892
Default RE: Help
thanks blu, Ioav that is what I was talking about chekc out that link and run the test... the bike will tell you what is wrong
gusotto
General Topics/Tech Tips
Nov 7, 2016 04:25 PM
sporty87
Dec 22, 2015 12:33 PM
ripperace
Jun 2, 2010 06:47 PM
PigInaBlanket
May 23, 2008 08:27 AM
fastolds
Jun 10, 2007 09:27 PM
