Hey everybody,
I just installed my side mount. Hardest part was running the wire down the fender tube. Thanks to a post here I was able to wire it to the extra place in the taillight and it works perfectly. I think it turned out pretty good for 50 bucks.
$19 side mout
$29 LED frame
nice man... i ran my wire from the harness under the seat, then under the swing arm... i have given up on the wires under my fender, my bike is too low for it, just rubs right though on bumps...
Hey Joe,
I ran it through the rubber tube attached to the bottom of the fender that the taillight wires are ran through. It was a little tricky but with a wire hanger and a little axle grease it got it to work. I ran the wire under the swing arm and tucked it in the bottom belt guard.
I love it the way it makes my bike look. The LED is nice and bright. Which is nice cince most my riding is done at night.
don q, think you could repost the photos please? i'd like to get a look at this. also, running the wire under the fender, i'm assuming you had the bike jacked up or the wheel removed?
I see a lot of board members that post img links but no images. I don't understand this.
Everyone says it looks nice but I can't see it. I've tried to copy and paste the image in a new browser and it doesn't work. How do you view these links?
Thanks in advance.
I put my picture on photobucket then copy the (IMG) code and paste it below my message and if it works you should see a picture of my bike below.
Thanks in advance.
The image codes you see like that are from before they switched the forum over. Alot of old images were lost in the process because of the change.
