Pipe Dope?
Old Jun 11, 2008 | 06:59 PM
beaverretriever's Avatar
beaverretriever
Default Pipe Dope?
Anyone found that the stealer used pipe dope on your drain plug instead of a new O'ring? Stealer did my 1k service as part of the purchase and when I changed it myself there was nothing left of the O'ring and it was covered in pipe dope? WTF?
Old Jun 11, 2008 | 07:13 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Default RE: Pipe Dope?
The only drain plug I use pipe dope on is my primary plug due to the fact the plug is a pipe thread. The O ring issue would be hard to prove, thats a lesson learned. Now you should learn how to change your fluids, or have a riding partner teach/show you.
Old Jun 11, 2008 | 07:34 PM
tlb's Avatar
tlb
its not pipe dope, it teflon paste. white colored paste to help it seal, i guess. I know the fix my hog video tells you to use it on the drain plugs.
Old Aug 15, 2008 | 11:45 AM
TexasUltra's Avatar
TexasUltra
Yep, just found it doing my 1st home change @ 15k. I guess the stealership didn't want to spring for an o ring. This is what came off (new o ring at top)
Is the old o ring supposed to be that chewed up and distorted after one oil change??? Anyone using teflon tape instead?
Old Aug 15, 2008 | 12:08 PM
Solitaree1's Avatar
Solitaree1
Default Pipe dope
Pipe dope AND an o-ring.
Old Aug 15, 2008 | 01:07 PM
ord sgt's Avatar
ord sgt
I use teflon tape on all my drain plugs. Can never have enough sealing. Also use teflon on my muzzleloading rifle. Makes it easier to take apart for cleaning.
Old Aug 15, 2008 | 01:31 PM
bberck's Avatar
bberck
I changed my Oil at 1k and put new o-rings on then at 3k I changed fluids to install my Chrome Motor package. My o-oring was pretty ate up, not as bad as yours but was in bad shape.
Old Aug 15, 2008 | 01:37 PM
PigInaBlanket's Avatar
PigInaBlanket
Mine had some pipe goop on it when I changed my fluids. I just put new O rings on it and no more goop. I'll use goop and an O ring next time. Couldn't hurt.
Old Aug 15, 2008 | 02:24 PM
glideridemike's Avatar
glideridemike
I use a dab of wheel bearing grease on the threads of my primer/assy on my muzzy. Comes apart slicker than snot on a ****
Old Aug 15, 2008 | 02:42 PM
thrillseeker's Avatar
thrillseeker
I've had the same o-rings on all three drain holes, since new, for 17k miles. I've never seen the need to replace, they are always in good shape.
I do use teflon tape on primary plug, but only cuz I torqued to foot lbs instead of inch lbs the first time I did my own service.
I've read over the years that its common to use dope... i don't think the dealer did you a dis-service by doing it... probably did it in your best interest.
