Fat Bob heat shield rattle
Old Jun 18, 2008 | 08:09 PM
hogsbreath08's Avatar
hogsbreath08
Stage I
Default Fat Bob heat shield rattle
Has anyone had a issue with the heat shields rattling on the 08 Fat Bob?
I took it to the dealer, but it was rattling again after an hour.
It appears that there is only two clamps on each shield but nothing holding down the ends where they meet the bottom shield.
&nbsp\\;
Any ideas?
&nbsp\\;
Thanks.
&nbsp\\;
Old Jun 18, 2008 | 09:36 PM
db252's Avatar
db252
Default RE: Fat Bob heat shield rattle
it seems to be a common problem for some. There should be 3 ratchet clamps on the lower heat shield. The dealer should be able to fix it easily.
Old Jun 18, 2008 | 09:50 PM
thebump's Avatar
thebump
I rotated mine so they are against each other tight, then clamped it down. Fixed it for good.
Old Jun 20, 2008 | 03:25 PM
FXDF MYK's Avatar
FXDF MYK
Mine has spots to mount other clamps at the bottom, but HD said it was for other pipes. I just took mine in for a rattle and it was just the pipes getting loose and everything needed to be tightened up.
Old Jun 21, 2008 | 06:35 AM
arnold's Avatar
arnold
MINE CAME LOOSE 3 TIMES IN A MONTH, THEY FINALLY REPLACED THE OFENDING PART, IT HAS BEEN FINE EVER SINCE.
balloo
Sep 5, 2014 08:23 PM
Slick12
Dec 15, 2013 09:34 AM
King_O_Road
Aug 6, 2008 10:37 PM
FXDF MYK
May 30, 2008 12:45 PM
arnold
Mar 2, 2008 08:08 AM
