Forward controls on 06 FXDLI
Old Jul 3, 2008 | 12:37 AM
45shutr's Avatar
45shutr
2nd Gear
Default Forward controls on 06 FXDLI
I'm thinking of forward controls on my 06 Dyna and was wondering...once the stock mid pegs come off, there will be a now un-needed&nbsp\\;clearance cut in the front pipe heat shield. I'm thinking it's gonna look a bit odd. Does HD have a replacement shield to fit without the clearance cut? Didn't find anything listed in catalog so just thought I'd ask to see how or if anyone has dealt with this before. Thanks.
Old Jul 3, 2008 | 01:28 AM
nigelgeast's Avatar
nigelgeast
Default RE: Forward controls on 06 FXDLI
&nbsp\\;
45 Shutr,
Hi, I had the forward controls fitted at HD before I picked up the bike, to be honest I never thought about it until&nbsp\\;I read you posting, you can see in the pic&nbsp\\;I have attached that you can see the cut out but you would have to look for it, it does not stand out,&nbsp\\; I am sure I would have noticed before now if it did,
[IMG]local://upfiles/65774/09CE3D2DCF0740EA9DACAE197C320EB0.jpg[/IMG]
Old Jul 3, 2008 | 02:39 AM
jmpancoast's Avatar
jmpancoast
What&nbsp\\;you need is the front heat shield off an 06 or later Wide Glide.&nbsp\\; Because the FXDWGI&nbsp\\;comes from the MoCo with forwards, their heat does not have the cut-out.
&nbsp\\;
The part number is 65966-06.&nbsp\\; I believe they run $52.00 at the dealer.&nbsp\\; I would ask around here as I imagine you can find a cheap take-off from another member.
Old Jul 3, 2008 | 05:38 PM
45shutr's Avatar
45shutr
2nd Gear
Thanks all for the info. I probably will leave it as is for awhile and when it finally gets to bug me I now know what part to buy.
Old Jul 3, 2008 | 06:41 PM
06dynablack's Avatar
06dynablack
wait till it cracks where it notched out then get a wide glide shield like it was suggested.luckily mine cracked while under 2 yr warranty and had it replaced with the wg one
Old Jul 3, 2008 | 09:32 PM
Zevron's Avatar
Zevron
The Wide Glide heat shield is the correct answer.
&nbsp\\;
joshp77
Jan 4, 2012 05:30 PM
Gary7
Feb 19, 2010 07:07 PM
markthecelt
Dec 28, 2008 11:04 AM
peakyboo
Jan 2, 2008 06:12 PM
Nach
Apr 26, 2007 02:45 PM
