30 lbs in 180 tire
Old Jul 3, 2008 | 10:55 PM
stevieg's Avatar
stevieg
Default 30 lbs in 180 tire
'Cause I'm height challenged I've done everything to get my Bob down so I can flat foot it: 11" 412 shocks, progressive front lowering kit, lower seat and big heels on my boots. Rough roads are killin' me and I looked into air shocks, 440s, etc and thought, since my 180 rear is hard as a rock I'd take it down from 35 psi to 30 psi. I'm only 135 lbs and always ride solo. Don't know if it's my imagination but it seems to ride a little softer. I did a search to see if this has been addressed and didn't find anything. What, if any, are the ramifications, problems, possible damage?
Old Jul 3, 2008 | 11:03 PM
Bluesssman's Avatar
Bluesssman
Default RE: 30 lbs in 180 tire
I would go to the tire maker web site and check recommended pressures. Running a tire low pressure can create some heat problems and excessive wear.
Old Jul 3, 2008 | 11:18 PM
rounder's Avatar
rounder
it should ride softer... I can feel the difference with my bike when I go from 35-39 for 2 up rides... I often forget to decrease the pressure on my next solo ride.... I personally think that one exact air pressure can not possibly be right for all people from 95-350lbs.
As for ramifications...well... does my gauge read exactly right... is it the same at all heights above sea level... and does it match every other gauge out there... doubt it.... but I do use it to measure my tire pressure.. may be off by 2-5 psi (don't really know).... Have not had a tire problem ever and have tons of tread left even after 7800 miles...
If I were you and you like 30psi then try out 31,32 maybe adding a couple psi will be just as comfortable and you will be only a couple pounds softer than the recommended 35... then again maybe your gauge reads a few psi too high and you will be exactly at 35.
Old Jul 4, 2008 | 12:23 AM
C-Cat's Avatar
C-Cat
your tire pressure is set for drag racing now!
Old Jul 4, 2008 | 01:20 AM
stevieg's Avatar
stevieg
Cool......
Old Jul 4, 2008 | 02:38 AM
carltex's Avatar
carltex
ORIGINAL: stevieg
Yes because you are using the flex in the tire as part of your suspension. I've had the same issue about psi. I only weigh 160, does the 36psi for the rear apply to me as well as someone that weighs 280. Hell , I'm 280 riding two up. To sum it up, sounds like you have done it all besides turn it into a rigid and it would really beat the hell out of you then.
Ga Blue Knight
18
Aug 2, 2013 06:41 PM
Knights2TheEnd
Jun 8, 2012 11:00 PM
JohnTM
Sep 13, 2011 11:20 PM
Thundr56
Wheels/Tires
Jul 8, 2009 07:31 PM
MB
Jun 27, 2006 04:34 PM
