Rear Fender Mod Paint Question
Old Jul 9, 2008 | 09:32 AM
rounder's Avatar
rounder
Default RE: Rear Fender Mod Paint Question
I have seen a matte clear but I don't know if it would be useful...trust JRK5892 and no clear... prime for sure though....
Old Jul 9, 2008 | 09:34 AM
xbox's Avatar
xbox
Good advice, thanks guys....
Ok I will prime it up sand it, then prime up again, then put on 3-5 coats of the
denim black.
After it's painted Should I leave it out in the sun for a couple of days to
cure up ?
Old Jul 9, 2008 | 10:35 AM
SK8ROD's Avatar
SK8ROD
i havent read what other folk have said here so i may be repeating,, BUT,, matt black is a very forgiving paint to use,, just go get some rattle cans and do it yourself,, i re-did my tank in the pic below and it comes out perfect,, the quotes you have got are totally insane!!
Old Jul 9, 2008 | 11:36 AM
xbox's Avatar
xbox
ORIGINAL: SK8ROD
Thanks for this info....
So after I do my fender and if it comes out good...
You think I can paint my tank badges while it's on the bike... ?
I was thinking of a bunch of tapped up newspaper and section off the whole bike,
then spray each tank badge (I have the big text that says harley davidson).
Old Jul 9, 2008 | 12:15 PM
SK8ROD's Avatar
SK8ROD
yeah i got some badges off ebay and gave it a shot,, i wanted to get a kind of embossed look with the moco logo, you know, so as not to give it too much emphasis as i also like the bare tank look,, it came out ace, very pleased with it.. The only deal with the standard Bob badges is how they would look all black, to me they looked like they would lose a lot of definition and kind of blob out, which is why i got the ones off ebay and shot them matt instead.. BUT there maybe some guy on the forum who has painted the stock badges and can post up a pic....
Old Jul 9, 2008 | 04:21 PM
buellrider76's Avatar
buellrider76
Just had that done to mine. Cost me 265.00 with stripping, welding, and repaint. The paint had to come from Harley and they charged 118.00 for a quart. I saw the invoice! The shop ate that cost though. They even undercoated the fender. Make sure they weld the clips back on or it's a bitch to rerun the wiring for you turn signals.
[IMG]local://upfiles/32794/CC24ADE607FD44C082D4B3D8D91483FF.jpg[/IMG]
[IMG]local://upfiles/32794/05E653244F354A7BADC7E8786074ED13.jpg[/IMG]
Old Jul 9, 2008 | 04:38 PM
Tele00's Avatar
Tele00
ORIGINAL: buellrider76
&nbsp\\;. The paint had to come from Harley and they charged 118.00 for a quart. I saw the invoice!&nbsp\\;
&nbsp\\;
&nbsp\\;
I believe that.&nbsp\\; any decent quart runs that much or more. But you get what you pay for...&nbsp\\; Looks great ..
Old Jul 9, 2008 | 04:54 PM
JRK5892's Avatar
JRK5892
True PPG makes a color that is pretty close! i would just use a rattle can, light coats and see what you think... REPAINT THE WHOLE FENDER! do not just do the part they worked on, or you will see the diff in paints... for the badges just wedge newspaper behind the badge and you will be golden.. Chipster did his in green came out great!
- one thing to remember... painting is 90% prep, 5% painting, 5% finish.... take your time with the prep, make sure it is perfect with primer, hit it with lights at all angles make sure you have it smooth as glass then start shooting the fender.&nbsp\\; start your spray with the can OFF the fender then go across it and stop painting once off the fender... this will prevent build ups that come with when the can first begins to spray. I have done ALOT of really nice paint jobs with rattle cans, just take your time... after your all done with it, i would let it set up for 2-3 days and maybe even heat it up a bit in the oven at like 125 for 20 min or so... just to help it cure.&nbsp\\; when you are putting it back on use some painters take and cover the sides completely this will prevent getting scratches in the paint as you do it... rattle cans usually shoot pretty thin, i would get one of those gun attachments just cause it is a pain to shoot something that large with the finger thnig and your fingers will have a tendancy to get into the spray and not allow for even coverage... you can do a great job with a rattle can! GREAT job!
Old Jul 9, 2008 | 10:51 PM
VenturaChop's Avatar
VenturaChop
hey man&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; u dont finish filler in 600&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\ ; you finish it in 180&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\ ; prime and block sand the prime with 400 wet then run your hand with some 600 wet till the 400 scrathes are gone&nbsp\\;&nbsp\\;&nbsp\\; i do this for a livin
Old Jul 9, 2008 | 11:16 PM
rounder's Avatar
rounder
ORIGINAL: VenturaChop
hey man \\\\\\; \\\\\\; \\\\\\; \\\\\\; u dont finish filler in 600 \\\\\\; \\\\\\; \\\\\\; \\\\\\; \\\\\\; \\\\\\; you finish it in 180 \\\\\\; \\\\\\; \\\\\\; \\\\\\; \\\\\\; \\\\\\; prime and block sand the prime with 400 wet then run your hand with some 600 wet till the 400 scrathes are gone \\\\\\; \\\\\\; \\\\\\; i do this for a livin
so run hand with no finer than 600 wet then shoot the color?
