helicoil
Old Jul 14, 2008 | 11:04 AM
2007z71's Avatar
2007z71
Default helicoil
Has anyone used a Helicoil to fix a stripped out spark plug? I would never do it on my SG but this is a small dirt bike (ttr125) so I think it may work. If anyone has used one how did you calculate the size you needed?
&nbsp\\;
Thanks
Old Jul 14, 2008 | 12:33 PM
dyna07custom's Avatar
dyna07custom
Default RE: helicoil
bring the plug with you and it they will give you the one to fit if its on line they usually ask the plug size If its stripped bigger than that You are prob in need of a head. I have done it to small engines no prob but never tried on anything bigger than 20 Hp
Old Jul 14, 2008 | 12:49 PM
wescoot2's Avatar
wescoot2
I've never used these but you may want to investigate these.
&nbsp\\;
http://www.wttool.com/category-exec/...air/page_num/3
&nbsp\\;
Respects,
Ed
Old Jul 14, 2008 | 12:57 PM
2007z71's Avatar
2007z71
I think those will work but I cant find the correct size. I need a 10X1mm
Old Jul 14, 2008 | 01:49 PM
wescoot2's Avatar
wescoot2
10x1mm in fine thread listed here...
&nbsp\\;
http://www.wttool.com/category-exec/...c_Inserts_Fine
Old Jul 14, 2008 | 01:51 PM
JRK5892's Avatar
JRK5892
have you tried to just re thread it to the correct thread? did you pull the spark plug witht he motor still hot? if you just re thread it, run it real fast then change the oil you should be cool.
Old Jul 14, 2008 | 07:21 PM
rbabos's Avatar
rbabos
ORIGINAL: 2007z71
&nbsp\\;\\\\\\;
Thanks
Stronger than original when done. I'd do it no problem. Some aircraft engines have them too.
Ron
&nbsp\\;
flyboyron
Aug 2, 2008 07:22 AM
51Moe
Jul 21, 2008 01:58 PM
donna.1965
Jun 18, 2008 11:23 PM
dg7080
Exhaust System Topics
Mar 8, 2008 11:09 AM
m.breen
Jun 17, 2007 11:24 AM
