hate the fxdl headlight, need options?
Old Jul 16, 2008 | 08:24 AM
lilsahara450r's Avatar
lilsahara450r
Default RE: hate the fxdl headlight, need options?
i am also very interested on this subject. i have an 04 and i hate that eyebrow thing and headlight. but i dont know if there is anything i can do to change it
Old Jul 16, 2008 | 08:29 AM
Kockdiesel's Avatar
Kockdiesel
is there a black HID light available?
Old Jul 16, 2008 | 08:32 AM
timberwolfz28's Avatar
timberwolfz28
JP cycles has a mount that might work part number 310-445
Old Jul 16, 2008 | 09:05 AM
rounder's Avatar
rounder
ORIGINAL: timberwolfz28
2003 Trying to see how I'd mount one from the bottom
drill the bottom tree.
Old Jul 16, 2008 | 09:08 AM
rounder's Avatar
rounder
can use the trim piece from 883/1200c for the top triple tree to replace where the brow was...
Old Jul 16, 2008 | 09:09 AM
rounder's Avatar
rounder
the 883/1200c headlight and mount will work as well
Old Jul 16, 2008 | 09:26 AM
rounder's Avatar
rounder
check out beendad's sportster in his sig on post #2 https://www.hdforums.com/m_3629393/tm.htm
stock front with only a hooded trim ring..
Old Jul 16, 2008 | 09:33 AM
timberwolfz28
hard to see in the small picture but I like the look
Old Jul 16, 2008 | 09:52 AM
FastHarley's Avatar
FastHarley
Former Sponsor
All great posts above. Yes you can drill the bottom tree &amp\\; install any bottom mount light you need. There is lots going on in the lighting industry. I own 2 bikes &amp\\; I am putting on a pair of Adjure 3" spot lights &amp\\; 1" Led Beacon lights (turn/running)
FastHarley's Avatar
FastHarley
Former Sponsor
I am also using a 5 3/4" headwinds w/HID. I plan on mounting and centering them on the fork tubes and level with the center of the headlight along with flush. I plan on making a mount to incorporate the turn signals that are parallel with the forks (swept froward).
