07 Dyna Possibility
Old Mar 13, 2006 | 09:04 PM
JonHanna's Avatar
JonHanna
Default RE: 07 Dyna Possibility
Every BOB they get in my area gets gone almost the week it goes to the sales floor.
Old Mar 13, 2006 | 09:32 PM
WillieC's Avatar
WillieC
My dealer told me that eventually they will put the VROD type engine in all models because the old
VTwins will not be able to meet the EPA specs ansd still run good.
According to him they are already experimenting on it with varoius models.
Willie
Old Mar 13, 2006 | 09:41 PM
JonHanna's Avatar
JonHanna
ORIGINAL: WillieC
Willie
[sm=boosign.gif][sm=noooo.gif][sm=smiley21.gif]
Old Mar 13, 2006 | 11:01 PM
CraigC's Avatar
CraigC
The Revolution engine is a big step forward in technology and seems to be the wave of the future. They even sound great with aftermarket pipes but for all its strong points, it just ain't the same. Just doesn't sound like a Harley. In the five years it took me to finally buy a Harley, I thought long and hard about the V-Rod. The reason being that I was afraid the TC88 wouldn't be enough to satisfy me. Once I was finally able to start riding and experience a few different bikes, my opinion changed drastically. I know for a fact that I would've been disappointed with a V-Rod. They are awesome bikes and are probably a blast to ride but it just would've been the wrong bike for me. I'm 150% tickled slap-*** to death with my Street Bob! They start putting a Revolution motor in the other product lines and I'll start buying used bikes.
Old Mar 13, 2006 | 11:04 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: WillieC
Willie
Unfortunately, you are probably right. Might not be the Vrod but the days of the air cooled MC engine are numbered. I think they will make a water cooled TC88 style engine so not to change the style of all the bikes that have them. It will have to be larger to accomodate water jackets but will probably look the same on the outside with a small radiator up front. Wont make the EG and RK style bikes look much different but the Dyna looks will suffer. So, hang onto your current bike.....it may just be worth more than you payed for it someday.
Old Mar 13, 2006 | 11:07 PM
KBFXDLI's Avatar
KBFXDLI
ORIGINAL: CraigC
My buddy has a Vrod with Rinehart straight pipes on it and it does sound like a Harley. I was very surprised the first time I heard it. Almost as loud as a TC88 with SEII slip ons. I could own one with that setup.
Old Mar 14, 2006 | 12:20 AM
grizzly's Avatar
grizzly
ORIGINAL: PowerCobra98
ORIGINAL: grizzly
I have not heard that, but if its true, I am glad I bought my 06 when I did. Why on earth would you need a counter balancer on a rubber mounted motor? Doesnt make any sense to me.
Aren't V-Rods rubber mounted and balanced??
Automotive-style full pressure bearing journals keep things steady while a single crank driven forged steel counter weight balances out the vibes.
The Revolution motor is rubber mounted in Harley's first steel perimeter frame.
You sir, are correct. I assumed since the engine can safley rev to 9000 RPMs that it was not.......I was ....WRONG....
Still, I dont see them putting the B motor in the Dyna. Eventually going to a revelution type motor across the board to keep up with the EPA regs...that I see comming...sooner than later.
Old Mar 14, 2006 | 12:22 AM
grizzly's Avatar
grizzly
ORIGINAL: KBFXDLI
ORIGINAL: WillieC
Willie
Or a serious PITA to keep on the road....... Regardless, I am glad I bought a new Dyna when I did.
Old Mar 14, 2006 | 10:36 AM
fl_799's Avatar
fl_799
You can bet that any replacement motor is and has been in the works for at least the past 3 years. I read the chapter of the birth of the TC88 motor in the Book 'Harley Davidson Century' and that motor took about 6 years to reach the market in 1999. They fought for tooth and nail resolving every bug and oil issue they came across but they were still working on a basic air cooled, 45 degree v-twin. You would think they would know that motor better then anybody but the sad truth is that they has to learn all over again after the brain dump of experience left the Moco in the 1970's.
The point is, If the V-Rod motor is not the future of HD (I hope it's not), they are certainly getting help from outside the company. Willie G. will lay down the parameters i.e displacement, OHC/Pushrod, Air/Water cooled etc. I can't see him putting his stamp of approval on a water cooled twin with bolt on cooling fins and overhead cam's. 'Ain't gonna happen. Hell, the MOCO would not even consider adding an oil cooler to the TC88 motors when it could have saved the MOCO millions of dollars revising the head cooling and oil flow issue on the Twin Cam prototypes. If there is money to be spent on development (and there is PLENTY), the MOCO will find an innovative way to produce the air cooled, 45 degree v-twin AND meet the future EPA's guidelines for noise and pollution. I just can't see them doing otherwise.
Old Mar 14, 2006 | 03:55 PM
intruder400ex's Avatar
intruder400ex
Putting the 88 b in a dyna would be a step backwards in mt opinion. The motor doesnt have the same power and costs more to produce.
Steve
