WOT detonation
Old Jul 18, 2008 | 08:37 PM
sargek's Avatar
sargek
Default RE: WOT detonation
hockey8787 - not wound out that much? No tach!
Old Jul 18, 2008 | 08:38 PM
sargek's Avatar
sargek
rounder - last tank was Valero, normally do Chevron. I haven't seen a connection to the brand, only the temperature
Old Jul 18, 2008 | 08:39 PM
sargek's Avatar
sargek
Azgunner - no timing adjustment. I always run 91-93. Good point on punching it - normally only does it when I am really winding it out in 4th or 5th and it's hot.
Old Jul 18, 2008 | 08:41 PM
sargek's Avatar
sargek
Good troubleshooting hints all, appreciate it. Wondering if detonation is because of extreme heat and if stock main jet, a lean condition. NEVER detonates at any speed if the temps are cooler.
Old Jul 18, 2008 | 08:42 PM
sargek's Avatar
sargek
Damn, what a P.I.T.A. Feels like a morse code message.
Old Jul 18, 2008 | 08:52 PM
wescoot2's Avatar
wescoot2
Since the only time its happening is when its very hot out, I would tend to think its running a little lean.&nbsp\\; I would try richening it up a bit and see how it reacts.&nbsp\\; As was pointed out, carb adjustments are a happy medium.
&nbsp\\;
Respects,
Ed
Old Jul 18, 2008 | 09:03 PM
hockey8787's Avatar
hockey8787
good luck
Old Jul 19, 2008 | 06:54 AM
sargek's Avatar
sargek
ORIGINAL: wescoot2
Since the only time its happening is when its very hot out, I would tend to think its running a little lean. \\\\\\; I would try richening it up a bit and see how it reacts. \\\\\\; As was pointed out, carb adjustments are a happy medium.
Respects,
Ed
My thoughts exactly, just wanted to validate my thinking. Thanks Ed - will try one size larger main.
Paul
Old Jul 19, 2008 | 07:31 AM
wescoot2's Avatar
wescoot2
I'm not sure what size your slow jet is.......just to give you an idea of what I'm running...
Main 195&nbsp\\;&nbsp\\; Slow 48&nbsp\\; Screaming Eagle AC with V&amp\\;H Short Shots.
&nbsp\\;
This is for the Chicago area, temps typically 80's&nbsp\\; although sometimes the low 90's
Respects,
Ed
Old Jul 19, 2008 | 07:49 AM
sargek's Avatar
sargek
Slow jet is a 46 and I raised the needle up .050 with 2 #4 washers. Your numbers are a good guide. Thanks again.
