Oil cooler?
Old Jul 26, 2008 | 11:15 AM
firestop52's Avatar
firestop52
Default Oil cooler?
I was thinking about buying a oil cooler.
firestop52's Avatar
firestop52
Default RE: Oil cooler?
It seems like a good idea.
Old Jul 26, 2008 | 11:16 AM
firestop52's Avatar
firestop52
Is this wasted money or not.
&nbsp\\;
Old Jul 26, 2008 | 11:17 AM
firestop52's Avatar
firestop52
Sorry, having trouble posting more than one line. Thanks for the help.
Old Jul 26, 2008 | 11:42 AM
greg3131's Avatar
greg3131
is the install difficult ?
Old Jul 26, 2008 | 11:53 AM
dyna rider's Avatar
dyna rider
I went with a Harley oil cooler and installed it myself. It isn't difficult but there are some catches. You have to have a 7/16" allen wrench or allen socket to remove the old adapter. You also have to move the voltage regulator up and take the front motormount loose to mount the cooler. None of this is hard in itself but all together it is a bit of a pain. I could immediately feel the motor run cooler in traffic. If you are going to do a lot of performance mods, I think it is a good idea.
Old Jul 26, 2008 | 11:59 AM
firestop52's Avatar
firestop52
Wow, I didn't think it would make such a noticable difference, thanks for the help.
Old Jul 26, 2008 | 01:25 PM
SC-Longhair's Avatar
SC-Longhair
He could also use one of the long slender frame mount type coolers.
Old Jul 26, 2008 | 04:40 PM
dyna rider's Avatar
dyna rider
FYI- it lowers the temp about 20 degrees. I haven't had my bike go into the one cylinder shut down since I installed it. It only happens when I am stuck going nowhere in traffic.
Old Jul 26, 2008 | 05:29 PM
ngoti8tor's Avatar
ngoti8tor
As long as you remember that an oil cooler doesn't do anything unless you're moving. Also, the warm air coming out of the oil cooler hits the engine.
