Bags on my Bob
Old May 24, 2009 | 11:30 AM
Sweedy's Avatar
Sweedy
Hi,about the barebacks,when i line up the front and rear male bareback on the bike
the front are about 3 mm more outwards than the rear.Have followed the instructions
from cyclevision and mount the spacer on the rear males.
Have now tried to shim the rear female bareback with washers 3mm between the bag
and bareback.Whas thinking the steel plate support on the bags are bent because when i tightend the female bareback it will not fit at all.
I like the looks of the barebacks but i mounted a set of easy brackets on my wifes bike and
this was a "direct fit" to the bike.Maybe i should bought these myself to.
But is any of you with barebacks who need to shim with washers between the bag and
the rear female bareback ??
Old May 24, 2009 | 01:17 PM
ronny c.'s Avatar
ronny c.
mine were 90.00 bucks from shadetree, mounted w/ 100 pd. wire ties. 1000 miles w/ no problems
Old May 24, 2009 | 06:21 PM
Robert Le Gras's Avatar
Robert Le Gras
I bought MoCo leather non-detachable bags. I don't have another vehicle, so I use my bags a lot. I've gotten to like the look, I like the bags a lot.
Old May 26, 2009 | 11:09 AM
Sweedy's Avatar
Sweedy
Hi,just sending you a pic of the male barebacks on the bike so you can see the
difference between front and rear bareback.
Maybe not so easy to align this up without using a bunch washers or maybe i got
to short spacers.
Anybody else who have noticed this on your male barebacks ??
Old May 26, 2009 | 01:02 PM
Stanger's Avatar
Stanger
I have the barebacks system and I did use a washer to get the correct alignment. I did some research on them and it all depends on what the back of the bags is like. On mine the mounting holes are not on the same plan, so I needed to shim up the barebacks with a washer to get them to aling correctly. It does take some time to get the alignment correct, but once I got it, it is easly 10 seconds on and off. They are machined with tight tollerances so a good alingment is required. But once you get it, they are great in my opinion.
Old May 27, 2009 | 01:20 PM
Sweedy's Avatar
Sweedy
Ok Stanger,thanks.I have oem bags part.no 90564-06B and like the looks of both bags and barebacks.Should try to align it all up.
Old May 27, 2009 | 02:58 PM
JRK5892's Avatar
JRK5892
check out this system... these are the ones i am going with to mount my bags
http://www.edgeleather.com/Table/Har...yna/index.html
they are local to me... next week (after i gets paid) i am going to go in there and buy a set... the customer service ROCKS
Old May 27, 2009 | 03:13 PM
June Bug's Avatar
June Bug
I (or should say hubby) put Easy Brackets on mine. They went on fairly easily, but then he had to modify the setup when I put 1" lowering blocks on which made the bags rub against the shocks. Doesn't look beautiful, but it works. I know, I know - bikes look better without bags. (And windshields too) Agreed. But I need storage when we go on longer trips especially.
Anyway, the Easy Brackets were a lot easier to deal with than Ghost Brackets, which hubby had had on a previous bike of his.
But Benwiggin, back to your original post - NICE LOOKING!!
Old May 28, 2009 | 08:33 PM
maddghost's Avatar
maddghost
Are ya going for the easy carry strap too? Only another 36$$o's ,....just teasin' big guy!
I have the same ags as Benwiggin,not too fancy but real practical I like 'em!
Old May 28, 2009 | 10:14 PM
emwolb's Avatar
emwolb
man you got it goin on with those bags. all stealth too. lookin sharp. i like the look, and they'll surely be practical when going on a trip too. nice job.
