OIL LEAK
Old Jul 30, 2008 | 08:41 AM
Old Texas Gringo's Avatar
Old Texas Gringo
Default OIL LEAK
I'm looking at buying back my 03 Dyna eith about 7K miles on it. The present owner said it is leaking oil from the rocker box or the cover. Is this just a gasket problem?&nbsp\\;
Old Jul 30, 2008 | 09:58 AM
DOORZ's Avatar
DOORZ
Default RE: OIL LEAK
It could be just about anything.&nbsp\\; I had a friend that had a rocker cover bolt actually fall out, and was causing the oil leak.&nbsp\\; You can at least start with checking to make sure the bolts are all properly torqued.
Old Jul 30, 2008 | 10:01 AM
JRK5892's Avatar
JRK5892
pull off the boxes replace the breathers put on new gaskets, torque to spec and your golden!
Old Jul 30, 2008 | 11:23 AM
SC-Longhair's Avatar
SC-Longhair
Sounds like this is a sight-unseen situation. Look at it first.
cruiser66
Exhaust System Topics
Jan 7, 2016 02:49 PM
Cal71Kicker
Jan 27, 2013 04:01 PM
racinghoss
Aug 21, 2012 08:00 PM
SteveXL
Sep 15, 2008 11:42 PM
SimonW
Oct 5, 2006 12:42 AM
