Stripped Lower Front Engine Mount Bolt
Old Jul 31, 2008 | 12:43 PM
ladodgerdog's Avatar
ladodgerdog
Default Stripped Lower Front Engine Mount Bolt
During an oil cooler install to my '06 Super Glide, I over tighten the front lower engine mount bolt[:@].&nbsp\\;Now it justs barely grabs. I still took it around the block, to get the oil to move through the cooler. I guess I should invest in a tap and dye set. Any suggestions?
&nbsp\\;
This install needed a 7/16 hex. I had such a hard time finding one. Most sets went up to 3/8. The ones that went over skipped 7/16 and went stright to 1/2. I could not even find just a single without special ordering it. My 2 hour job turned into 5 days, waiting for NAPA to get me the right size hex. Why was a 7/16 hex so hard to find?
Old Jul 31, 2008 | 12:57 PM
rounder's Avatar
rounder
Default RE: Stripped Lower Front Engine Mount Bolt
ORIGINAL: ladodgerdog
you did not shop at Sears!????
Old Jul 31, 2008 | 02:58 PM
JRK5892's Avatar
JRK5892
or acehardware! personally i would just re tap it... HARBOR FREIGHT! they got a nice kit
Old Jul 31, 2008 | 06:36 PM
ladodgerdog
Yeah went to Sears, Sears Grand, Harbor Freight, HomeDepot, Lowe's, NAPA, Ace, Long Beach Motorcycle Swap Meet, and a couple of independent hardware stores. Even the maintance department at work. By the way, a 11mm is a pretty close fit and also just as hard to find.
Old Jul 31, 2008 | 07:52 PM
ladodgerdog
Here's a pic of the new oil cooler...
&nbsp\\;
Old Jul 31, 2008 | 09:46 PM
0ut1aw's Avatar
0ut1aw
did the same thing
&nbsp\\;
I replaced the mount ~75.00 at zanottis
&nbsp\\;
it needed replacing anyway
Ozark Joe
EVO
May 28, 2017 10:54 AM
Mchad
Sep 22, 2016 07:08 AM
R_W_B
Dec 3, 2010 08:15 PM
R_W_B
Nov 24, 2010 09:25 AM
pcbunn
Aug 26, 2010 10:35 AM
