The Continuing Saga Of My Pinging Wonder
Old Aug 1, 2008 | 05:28 PM
garyhendley's Avatar
garyhendley
Default RE: The Continuing Saga Of My Pinging Wonder
great info guys thanks-ride safe
Old Aug 1, 2008 | 07:04 PM
sargek's Avatar
sargek
Pinging isn't normal. This explains it better than I can: http://en.wikipedia.org/wiki/Engine_knocking.
Old Aug 1, 2008 | 08:33 PM
expy's Avatar
expy
I put in SE triple plat. in my 07 FXD.&nbsp\\;Sorry cant give you the link but it was part #32997-01.&nbsp\\;These are a slightly colder heat range and have performed perfectly, in fact I no longer have a pinging on hard accel. YMMV.
Old Aug 2, 2008 | 03:19 AM
sata6's Avatar
sata6
um this may be a&nbsp\\;silly qeustion but are you using premium fuel, and keep the reevs up it is 96 quebs
Old Aug 2, 2008 | 03:21 AM
sata6's Avatar
sata6
and pinging is not normal under any cercomstances that tells you you are lugging to much, over heating, or poor fuel
Old Aug 2, 2008 | 07:39 AM
OhAteFatBob's Avatar
OhAteFatBob
I would say that I&nbsp\\;might lugged it a little bit....if you count going WOT between 1st &amp\\;\\\\\\; 2nd &amp\\;\\\\\\; 3rd without speed shifting as "lugging". Couldn't help it wanted to see what she could do.
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
Old Aug 2, 2008 | 07:42 AM
OhAteFatBob
But it is most annoying when I go about 1/2 throttle going up hill just in normal acceleration. Gonna try those spark plugs next.
Old Aug 2, 2008 | 01:03 PM
Biggol's Avatar
Biggol
Do you downshift before you go up that hill?
rbabos's Avatar
rbabos
ORIGINAL: OhAteFatBob
If you had bike dyno tuned the antiknock may have been turned off and left off. Wire and plug change may have deactivated it's function. Ping is caused from low octain, too much advance or too much heat. Correctly tuned it will not ping even out of a lugged state full throttle, if you are crazey enough to do that.
Ron
Old Aug 2, 2008 | 03:32 PM
OhAteFatBob
ORIGINAL: Biggol
&nbsp\\;\\\\\\;
How do you downshift when you are in 1st gear and going 30 MPH and trying to get to 50MPH?
