Shock torque values please
Old Aug 1, 2008 | 11:58 AM
albngore's Avatar
albngore
Default Shock torque values please
Please tell me the factory torque specified for the low rider upper and lower shock bolts. I believe each is torqued differently. Thank you, Brad
Old Aug 1, 2008 | 12:05 PM
boss's Avatar
boss
Default RE: Shock torque values please
upper is 75-85 ft pounds
&nbsp\\;
lower is 30-40 ft pounds
&nbsp\\;
dont forget the loctite
Old Aug 1, 2008 | 12:21 PM
rounder's Avatar
rounder
my service manual has both upper and lower at 25-40 ft-lbs....use blue loctite...
Old Aug 1, 2008 | 03:58 PM
albngore's Avatar
albngore
Now isn't this a bit confusing\\; different values from two different people. Let me be more specific 2002 Dyna Low Rider. What I might do is just get out my torque wrench and gently creep up on torque on the bolts now attaching my shocks. That way I will get close to what is required, eh? Thank you all.
Old Aug 1, 2008 | 06:34 PM
boss's Avatar
boss
well you didnt tell us in your first post what year it was.&nbsp\\; my information came from my 07 h.d. service manual.
&nbsp\\;
Old Aug 1, 2008 | 07:11 PM
albngore's Avatar
albngore
My apologies for not being adequately specific. I did not suspect that newer versions would have different specs. Thank you.
Old Aug 1, 2008 | 07:40 PM
jsbridgew's Avatar
jsbridgew
The original torque values were WAY off!....'rounder' has them right.
Old Aug 1, 2008 | 07:44 PM
mud's Avatar
mud
ORIGINAL: jsbridgew
I disagree.
mud
Old Aug 1, 2008 | 07:47 PM
jsbridgew's Avatar
jsbridgew
hold on, 25-40 pounds is a little light.... honestly, though....if i had cranked those upper bolts to 75 pounds, I'd have either stripped the strut or snapped the bolt.. i remember running into this problem when i changed the stock out to the 440s
Old Aug 1, 2008 | 07:51 PM
mud's Avatar
mud
ORIGINAL: jsbridgew
Paul, Ive had the shock bolts on and off my 06
probably 50 times. Torqued to 85 (top bolt) everytime.
1/2 inch fine thread.
mud
