flywheel swap?
Old Aug 4, 2008 | 11:54 AM
sick_dyna's Avatar
sick_dyna
Default flywheel swap?
does anyone know if a flywheel off a 00 dyna lowrider will fit on a 07 superglide?
Old Aug 4, 2008 | 12:12 PM
mud's Avatar
mud
Default RE: flywheel swap?
ORIGINAL: sick_dyna
probably not.
what are you trying to accomplish??
mud
Old Aug 4, 2008 | 03:04 PM
sick_dyna's Avatar
sick_dyna
I've been hearing that the flywheels off a new dyna arent as strong as the older dynas so when you build up the engine to over 100" the flywheel fails. So I was wondering if you could swap the older flywheel with one off a new dyna so in a sense it would be stronger, less likely to fail when adding uprgrades to the engine. Does that make sense?
Handsome
Oct 23, 2019 05:16 PM
leafman60
Nov 12, 2016 10:31 PM
darkcustom48
Oct 10, 2012 03:29 PM
gnip
Jul 10, 2012 09:09 PM
MDodson
Jul 29, 2007 12:56 PM
