Going back to mid controls, much work?
Old Aug 4, 2008 | 06:31 PM
bosken's Avatar
bosken
Default Going back to mid controls, much work?
I´ve decided to convert back my forwards to mid controls. I have ALL the original Street Bob 07 mid hardware. Is it easy or do I have to remove the primary cover? Please don´t ask me why, just give me instructions .
Old Aug 4, 2008 | 06:33 PM
0ut1aw's Avatar
0ut1aw
Default RE: Going back to mid controls, much work?
If the rod was removed inside the primary you have to go back in to replace if not then its easy
Old Aug 4, 2008 | 06:36 PM
0ut1aw's Avatar
0ut1aw
in other words if it was done right it will be hard
Old Aug 4, 2008 | 06:40 PM
maddghost's Avatar
maddghost
I'm curious when they remove the rod do they just insert a cap to plug the hole?
Old Aug 4, 2008 | 07:20 PM
Rangerbob's Avatar
Rangerbob
ORIGINAL: maddghost
&nbsp\\;
Yes, the hole through the primary cover has a gasket between the inner &amp\\; outer cover. So it is just a through hole.
Old Aug 4, 2008 | 08:26 PM
0ut1aw's Avatar
0ut1aw
you know, I do forward controls and mid pegs.&nbsp\\; works good to give extra foot position.&nbsp\\; just take everything off the mid pegs and mout in stock pposition
Old Aug 5, 2008 | 01:16 AM
bosken's Avatar
bosken
Ou1aw, sounds like a good idea...i´ll try that..
Old Aug 5, 2008 | 07:45 AM
SK8ROD's Avatar
SK8ROD
good move,,
Old Aug 5, 2008 | 07:56 AM
0ut1aw's Avatar
0ut1aw
After you put them on be careful putting your feet down till you are used to them, place feet extra wide...
Old Aug 5, 2008 | 10:18 AM
ghostd00d's Avatar
ghostd00d
I have forwards also.&nbsp\\; Left the mid pegs in for about a day.&nbsp\\; Decided that on anything over a 100 miles I could put them back on.&nbsp\\; Otherwise looks pretty stupid.&nbsp\\; IMO
