CAN YOU
Old Aug 4, 2008 | 11:31 PM
MAX EVO's Avatar
MAX EVO
Default CAN YOU
powdercoat the silver part of the engine on the 09 Street Bob or paint that are to retain the all black look?Would it be a major job ?
Old Aug 5, 2008 | 07:25 AM
dyna rider's Avatar
dyna rider
Default RE: CAN YOU
I'm pretty sure the parts are powder coated at the factory and cooked before the engine is assembled. I wouldn't want to cook mine with it already assembled. I'm sure it can be done but it would be expensive. There are a few powder coaters here on the forum I'm sure they would know. Try Joe ,aka jrk5892
Old Aug 5, 2008 | 08:00 AM
dyna07custom's Avatar
dyna07custom
Default RE: CAN YOU
I thought the motor on a street bob is black
Old Aug 5, 2008 | 08:11 AM
maddghost's Avatar
maddghost
Default RE: CAN YOU
sounds like alotta work to me!
Old Aug 5, 2008 | 10:02 AM
rounder's Avatar
rounder
Default RE: CAN YOU
05 superglide custom as of a week ago sporting a black engine....lot of work...looks way better than silver....will be durable but not as much as the stock powder coat....
Old Aug 5, 2008 | 10:04 AM
rounder's Avatar
rounder
Default RE: CAN YOU
best to take off inner primary to get all the casing on engine and tranny....
I used 1200 deg. high heat paint.... is not texture black but probably more durable and still has texture from the original silver powdercoat....
Old Aug 5, 2008 | 11:17 AM
JRK5892's Avatar
JRK5892
Default RE: CAN YOU
you would have to pull the part off the motor, if you bake the whole motor your just asking for troubles with the seals and gaskets... you have to pull it off, media blast, then powder, then re assemble
Old Aug 5, 2008 | 11:51 AM
shimmon's Avatar
shimmon
Default RE: CAN YOU
you may be better off going with an 08 and adding the 09 fender and other things...
Old Aug 5, 2008 | 01:53 PM
rounder's Avatar
rounder
Default RE: CAN YOU
ORIGINAL: JRK5892
how hot is the bake process vs the running temp of the engine?
Old Aug 5, 2008 | 02:40 PM
JRK5892's Avatar
JRK5892
Default RE: CAN YOU
you bake at around 335-375 for 12-15 min depending on the powder and the metal your doing, some get more and some get less,
