nooby question
Old Aug 6, 2008 | 06:17 PM
avd_111's Avatar
avd_111
6th Gear
Default nooby question
Does the rear fender matter as to which seat I have to have? I bought a 04 lowrider and for whatever reason it has a wideglide rear fender. I am lookin to swap for a solo seat but the seat I'm lookin at I guess fit's all Dyna's but the wideglide. Is this because the fender is different? Do I need to order 1 for a wideglide in order to fit my bike?
Old Aug 6, 2008 | 06:28 PM
glide05's Avatar
glide05
good question - I'm guessing that the hole in the fender is in a slightly different location.
don't know for sure. The corbin solo will all 04-05 dyna, and I think that's because it doesn't use the fender mount hole. LePera has a different fitment for WG and it uses the hole.
Old Aug 6, 2008 | 06:36 PM
Double00Aught's Avatar
Double00Aught
hmmm, that IS a good question.
Old Aug 6, 2008 | 06:43 PM
bberck's Avatar
bberck
The wide glide fenders hole is in a different spot, so a wide glide seat should work but others wont.
Old Aug 6, 2008 | 06:58 PM
glide05's Avatar
glide05
OK - I still don't know for sure - but since I have both fenders I did some rough measures.
The rearmost hole on a 04-05 WG fender is most definitely farther back than the rearmost hole on a Superglide fender, so a 2-up WG seat and 2-up lowrider seat are NOT interchangeable.
However, the solo mount hole for both fenders APPEARS to be in the same spot - relative to the hole that the grabstrap mounts to.
My guess - AND ITS ONLY A GUESS - is that solo seats that use this mount hole will interchange. Now - you'll probably hit issues if you try to add a pillion.
Have you tried contacting LePera? They will probably give a standard line, but if you get the right person, they might be able to tell you.
Old Aug 7, 2008 | 06:57 AM
avd_111's Avatar
avd_111
6th Gear
Thanks for all you imput. I dont know if it's the factory 2up or a widelide 2up seat I'm running. I'll have to call Lepera before I make my order. Thanks again.
Jan 29, 2024 06:59 PM
beanoboy
Apr 6, 2013 06:54 PM
sinjin
Jan 26, 2011 05:18 PM
butler742
Jan 9, 2011 04:01 PM
theoldguy
May 14, 2007 10:11 AM
