FXDF handlebar thickness?
Old Aug 11, 2008 | 09:53 PM
MNrider's Avatar
MNrider
Default FXDF handlebar thickness?
Are they 1.25" or 1" in the clamp area? I haven't taken them off to look, but man it's hard to find 1.25" pullback risers.
Thanks.
Old Aug 11, 2008 | 11:31 PM
hockey8787's Avatar
hockey8787
my wide glide has 1.25 if that helps any it's an 07 and your right hard to find
Old Aug 11, 2008 | 11:38 PM
MNrider's Avatar
MNrider
I should probably clarify on the risers. Ones that fit 1.25" bars are hard to find.
Old Aug 11, 2008 | 11:41 PM
fiend138's Avatar
fiend138
I though most if not all 1.25 bars 1" at the riser and at the controls?
Old Aug 11, 2008 | 11:51 PM
paul s's Avatar
paul s
It's 1.25" at the riser, 1" at the controls.
Old Aug 12, 2008 | 12:07 AM
fiend138's Avatar
fiend138
Well that sucks, what geometry are you looking for?
These guys have some
http://www.tejasthumpcycles.com/Part...bys_risers.htm
Old Aug 12, 2008 | 12:57 AM
MNrider's Avatar
MNrider
I have looked at the Wild1 risers. Those are all for 1" thick bars. The actual riser post is 1.25" though. I guess it will just be a matter of time. I would like to go an inch or 2 higher than stock and maybe 2-3 inches pull back. Something like that and still be able to use the stock cables.
Old Aug 12, 2008 | 07:44 AM
rounder's Avatar
rounder
you may just be the perfect candidate for some t-bars that will do just that.
Old Aug 12, 2008 | 01:19 PM
MNrider's Avatar
MNrider
Yep, that's probably my best option. Do you have any idea how much slack is typically in the control wiring?
Old Aug 12, 2008 | 02:36 PM
dyna07custom's Avatar
dyna07custom
I think 4" may be out of std cable reach you may want to order cables as well and brake line
