Adjust Clutch??? Need Some Help
Old Aug 30, 2008 | 12:25 AM
BoomSoon's Avatar
BoomSoon
Default Adjust Clutch??? Need Some Help
At 5000 I changed primary, tran and motor fluids. Very happy, saved bucks on labor and it was simple and satisfying for this newbie. However, someone told me since I didnt have the dealer do the service I should have my clutch adjusted.....He said if not you could fry your clutch? Huh? How do I know if I need to adjust it and if so how do i go about that? The lever is probably not as tight as when it was new, but..... Thanks
Old Aug 30, 2008 | 12:52 AM
cstolp's Avatar
cstolp
OK if you want to do your own service buy the derned service manual
Old Aug 30, 2008 | 05:08 AM
JRK5892's Avatar
JRK5892
bull ****.. easy... just loosen it all the way you can on the adj on the down tube off the cable, now break the nut loose in the middle of your clutch basket... back the set screw out a bit then screw it back in till it seats, after it does, back it out a 1/2 turn, and tighten it with the set bolt again... then just take the play out of the cable with the adj on the down tube again by tighening it... there is a real good how to below... it is easy!
this is about the best how to i have found
http://www.expertvillage.com/video/1...clutch-one.htm
Old Aug 30, 2008 | 06:29 AM
tramp's Avatar
tramp
you got to work on your bike
only way to learn and save money
when your done you know it's right
Old Aug 30, 2008 | 04:05 PM
BoomSoon's Avatar
BoomSoon
Default Thanks man. One more thing JRK
Hey I just changed the fluids.....Do I have to get another gasket? I know, its only a few bucks but Im an hour from the dealer. What do you recc?
Old Aug 30, 2008 | 04:16 PM
rdondes's Avatar
rdondes
Here's a very good clutch adjust video from the Expert Village online series of do it yourself videos.
Here's the link:
Regarding living far from a dealer, all parts can be ordered by mail and received in a timely way via UPS or Fedex from just about any Harley dealer. Just call their parts department.
Old Aug 31, 2008 | 12:01 PM
walkamile's Avatar
walkamile
If you do not adjust your clutch over many many miles I could see how the normal wear of the clutch plates could make it so the cable is so loose that your clutch wont engage. But I am not sure how you would "fry" your clutch unless is was maladjusted to the point where it was slipping when you were trying to ride.
P51Driver
May 21, 2013 07:15 PM
Anthony8858
Sep 11, 2009 09:05 AM
thomasf59
May 6, 2008 09:37 AM
clayman
Jul 9, 2006 10:23 PM
hAkron
Jun 6, 2006 04:53 PM
