fall away test
Old Sep 3, 2008 | 06:44 AM
hogdoctor's Avatar
hogdoctor
I've found 65 ftlb insufficient clamp load on the upper tree to keep it from sliding forward
between the star nut and hex nut on normal braking, so what you get is a hard clunk sound when you use the front brake, and a click sound when you hit the rear brake.
Repeat this process enough times and the material will wear down and you will lose the little clamp load you have and also lose neck bearing preload.
Hogdoctor
vette8494
Jan 2, 2009 09:37 AM
Norb
Great Lakes
33
Sep 9, 2008 09:13 PM
bishopanthonym
May 6, 2008 10:48 PM
Casper
Mar 18, 2008 11:40 AM
pearlsporty
Dec 30, 2007 10:01 AM
