fall away test
Old Sep 1, 2008 | 06:45 PM
harper764's Avatar
harper764
Angry fall away test
trying to do the fall away test on my 07 sb. i have the manual but i need some advice from those of you that have done this before. got the bike on the jack, made sure it is level with a level but i cant get the fork to stay straight so i can do the inspection. it constantly wants to fall to the left even with the bike perfectly level and no load on the forks. the balance point of the front tire is like 4 in to the right. im thinking thats not normal. also, how do you adjust the star nut? thanks in advance for the help.
Old Sep 1, 2008 | 07:00 PM
maddghost's Avatar
maddghost
Sorry I can't help you for the test,but I'm even sorrier to have to miss that avatar or your! It ws really a coo lcouple of frames!
Old Sep 1, 2008 | 07:02 PM
harper764's Avatar
harper764
yea it was pretty sweet. them was some nice T1Tz
Old Sep 1, 2008 | 07:04 PM
YellowHawk's Avatar
YellowHawk
Sounds like it's certainly too loose....I need to do this check too so I'll be monitoring this thread. Surely somebody will chime in with some help on this.
Old Sep 1, 2008 | 07:12 PM
maddghost's Avatar
maddghost
is the procedure not described in the manual?
Old Sep 1, 2008 | 07:23 PM
harper764's Avatar
harper764
it is, but it calls for the wheel to be straight and then tap the fender to measure when it starts to fall away, you do it to both sides then measure the points, but if the wheel wont remain straight, how can you do it?
Old Sep 1, 2008 | 07:36 PM
JerseyDevil's Avatar
JerseyDevil
Harper, I don't have the manual in front of me but I believe it mentions something about removing the clutch cable. The cable may be pulling your bars to the left. I've been wondering about doing it too, a little confusing.
Old Sep 1, 2008 | 07:37 PM
harper764's Avatar
harper764
it says only if the cable pulls it to the side, but its got plenty of slack in it.
Old Sep 1, 2008 | 08:00 PM
WS6 Formula's Avatar
WS6 Formula
Remove your clutch cable, it is pretty stiff and tends to want to straighten out to a relaxed position. Check all the wiring from the frame to the triple clamps and make sure there free. Does the front end turn smoothly? Bearings good? How did you determine that the frame is level?
Old Sep 1, 2008 | 08:02 PM
pococj's Avatar
pococj
Umm, you said the thing is falling to the left. The clutch cable is attached to the left. Plenty of slack or not, take the clutch lever assembly off!
