Remove your clutch cable, it is pretty stiff and tends to want to straighten out to a relaxed position. Check all the wiring from the frame to the triple clamps and make sure there free. Does the front end turn smoothly? Bearings good? How did you determine that the frame is level?
front end turns fine, no binding, noise etc....
i checked the levelness with a carpenters level
i had a really cool sig pic of a chick with a really nice set ot T!T$ cutting her shirt, but some jack stick decided to steal it and use it for HIS avatar now its not cool anymore. thanks DIP ZHIT thief
put the avatar back up anyway, never can have too much of a good thing...you know you had it first...by the way, (thread jack here) i've tried again and again to use a .gif for my avatar, but can't get any action (motion, movement, animation). Any ideas???
well if it is loose you wil not have binding for sure... take off the clutch assembly...
also you used the level on the brake disc? If not make sure the brake disc is perfectly level (perpendicular) to ground while the front fork is straight ...
didnt try it on the brake disk just the trees, tank,fender, and frame. its a small magnetic level. figure if it wasnt level, i might have seen it. ill try it though and see what i see
Where did you place that level?
Here's a few things; I did mine a couple of years ago when I was putting things back together and I think I may have had the whole clutch assembly off. With the brake master on the right and the caliper on the left balances the assembly out. I also had the upper triple clamp loose so that I could adjust the nut below the clamp. Follow the manual and I would also mark where it falls off to the left and right then the mid point between those would be your center.
you level from the brake disc and you really should use an angle finder (cheap at home deopot,lowes etc.) to be sure the angle is exactly 90º.
The balance point does not *have* to be in the center, it can be anywhere.
You're just checking the difference between the fall away point going to the left and the fall away point going to the right. Always start the swing from the fork stop.
If you're running a wide glide or FLH/T front end, check the top nut torque first. They tend to be undertorqued. My spec is 100ftlb to ward off the front end clunks.
If you need to torque it, take the nut off, flatten out the lockplate or replace it.
Put a thin coat of valve grinding compound under the lock plate and a thin coat of grease on the underside of the nut.. this will keep the anchor tab from getting ripped off as you torque the nut.
Hogdoctor
100 ft lb? the manual for my bike calls for 55-65 ft lbs i think. should i torque it to more than that?
