especially in low gears, engine seems not having fuel when I leave the right hand. engine cuts off and then starts working normally. so even changing the gears I have to right hand to provide fuel flow. otherwise bike does not breath. very strange !!!!! dealer changed fuel pump. but nothing changed. bike does not die but cut of fuel .seems to be stopping then jump forward.....any ideas ???
yes a few of us had a problem like this,it seems the easy cure on the road is to stop ,turn off ignition and re-start.The problem is caused by the IAC (idle air controller) movement being blocked by grunge building up in the throttle body. here is a link to the thread I started the other day LILbuddyWizer came up with the pertinent info for us! and kk6pg found info for cleaning up the crap! good luck and be careful!
And if that looks good I would think about the fuel or air filter. I wish i knew what bike you have and mleage.
thanks for your kind message. I have 06 wide glide and 4000 miles only. where is the link ? I cant see
Adjust your throttle cable first so it snaps back easily when you let go of the throttle. While in there lube the cables. See if that changes anything.
Everything works normally with throttle and cables.I have to keep throttle open otherwise bike sometimes seems to be cut off then jump suddenly. makes this in 1,2,3 gears. not at high speed. no ecm codes appear. what could it be ??? dealer said they will replace injectors and see.....
Do you have the 8 degree fuel injectors? If so make them put the 25 degree ones in. Mine had the 8 degree ones and ran like crap until they replace them. I'll post the TSB.
