Fat Bob Air Filter
Old Sep 2, 2008 | 09:42 AM
bjv11383's Avatar
bjv11383
Default Fat Bob Air Filter
Has anyone installed the Stage I air filter by screaming eagle??? I have the screaming eagle back plate w/ the K& N filter....bought it from FuelMoto. Well, when I had it installed I used the factory cleaner cover and found it rubbing on the underside of the gas tank, which made a little scratch...Not Happy!!! It seems to have moved higher than the original filter settting.....Has anyone else had this issue??? Can I run it with the filter and no cover????
Old Sep 2, 2008 | 09:54 AM
grandpawmoses's Avatar
grandpawmoses
I haven't run with that senerio but yes you could run it without a cover (not in the rain though). Why not put a spacer (a few washers) between the cover & filter to set it out a little?
GPM
Old Sep 2, 2008 | 10:04 AM
FATBOB67's Avatar
FATBOB67
I have the Screaming Eagle Stage 1, it has two spacers to keep it at a safe distance from the tank.
Derf_
Jun 9, 2016 03:29 PM
MikeSz
Aug 30, 2013 07:13 PM
SurfGuitar141
Exhaust System Topics
Apr 2, 2011 06:02 PM
SurfGuitar141
Apr 2, 2011 08:47 AM
nickd23
Feb 18, 2010 07:41 AM
