06 Street Bob performance
Old Sep 12, 2008 | 08:24 PM
Walshie's Avatar
Walshie
2nd Gear
Default 06 Street Bob performance
Picked up a 06 SB this week (better pics coming up soon). Its got Python pipes and a K&N filter and a Power Commander. I've been lookin around and see some people put the bigger cams in the 1450's.. How much of a difference would this give me vs my stock cams.. Any other other mods I can do to make this thing a little quicker? I'm used to my GSXR 750, love the comfort of the Bob but needs a little more pick up..
Old Sep 12, 2008 | 11:24 PM
chad peterson's Avatar
chad peterson
You'll notice it, if that's what you want to hear! Thing that sucks with the 06 and up is the final gearing ratio, it's like a 2.80 something and the 05 and older were around 3.15 So the 06's weren't as peppy. I put the 30t engine sprocket on my 06 and helped alot, but it wraps out pretty high on the freeway. I'm just waitin for a 32t. I also have a built motor though
Old Sep 13, 2008 | 04:10 AM
JRK5892's Avatar
JRK5892
i have an 06, V&H, custom map, plug wires, Stage 1 and tach... knowing where you are shifting is alot of it... i spank alot of newer bikes cause i know where i am and when to shift... a build will give you ALOT of power or just a simple cam... depends how crazy you want to get with it an how much money... i LOVE my 06... would not take any other year bob, mainly cause i love the 88ci motor... sky is the limit only weighed down by your check book...
Old Sep 13, 2008 | 08:45 AM
mud's Avatar
mud
Walshie, depending what cams you go with,
the difference can be very noticeable.
As to other mods, chad mentions gearing.
Here it's all about money money money.
About 2 grand you can do 95 inchs with cams and heads
Add 5-6 hundred (or so) for high performance pipes.
100hp/100tq easy with the right package
Or, I went for about 6-7 thou and wound up with 116 HP 150 TQ
A guided missile.
chad, Where did you pick up the 30T??
As to gearing,
You're comparing 06 6th gear to 05 5th - right???
The 06s are plenty peppy.
gear.....05.........06......06INT..........08
1st.....10.11.....9.876.....9.60.......9.312
2nd....6.958.....6.81.......6.61.......6.421
3rd....4.953.....5.064.....4.95.......4.774
4th....3.862.....4.164.....4.05.......3.926
5th....3.15.......3.477.....3.36.......3.279
6th.................2.96......2.88.......2.79
Old Sep 13, 2008 | 02:20 PM
JRK5892's Avatar
JRK5892
"Or, I went for about 6-7 thou and wound up with 116 HP 150 TQ
A guided missile."
holly crap!!!
Old Sep 13, 2008 | 02:30 PM
jamman's Avatar
jamman
you'd be suprised of what you can do with the powerband..
Old Sep 13, 2008 | 06:37 PM
SPECIAL ED's Avatar
SPECIAL ED
Whoever said it's all about what you want to spend got it right.A good 2 into one header like a Thunderheader will get you a little more horsepower and a bunch more torque than a set of duals or slip-ons but, it'll cost literally twice as much.Throw in a good dyno tune and you could be in the high 70s low 80s HP and maybe even up to 90 TQ about the same place you'll end up with a good drop in cam and dyno time.This is why you should have kept your gixxer.
JimiNales
May 14, 2017 02:02 PM
Walshie
Dec 26, 2008 05:52 PM
CK Bobber
Sep 4, 2008 07:05 PM
darkdyna06
Mar 26, 2008 09:54 PM
bluepaul
Dec 2, 2007 07:21 AM
