Saddlebag supports
Old Sep 13, 2008 | 03:17 PM
HoolyNI's Avatar
HoolyNI
Default Saddlebag supports
Fitted a pair of supports to 06 fxdci which required the indicator stalks to be moved back about an inch and wiring to be threaded thru the stalk.
Problem is back tyre must be coming up past the fixing nuts and rubbing against the wiring as copper is actually now exposed on the left hand side only, doesn't seem to be rubbing on the right.
Even if i can align the wheel to prevent any rubbing, it still means with two up and hitting a bump, tyre is coming within about 5mm of the fixing nuts.
Anyone else using this design of support:
And should i be concerned about design?
Old Sep 14, 2008 | 07:20 AM
HoolyNI's Avatar
HoolyNI
Just had a look at shock settings they are currently on "2" if i notch up to "3" would this increase clearance between tyre and fender?
Jaftica
Apr 13, 2019 07:42 AM
Badbagger
Jun 4, 2018 06:59 PM
Maleko
Aug 8, 2015 11:03 PM
sagebrush1976
Jun 28, 2012 03:21 PM
Cowboy Tom
Jan 19, 2007 08:10 PM
