Peg Scrappin...
Old Sep 18, 2008 | 07:42 AM
Dawg Rider's Avatar
Dawg Rider
You can upgrade the fork internals and the rear shocks, both of which should help. Works Performance is another popular brand in addition to the ones mentioned above. I was planning to go with YSS shocks from forum member (sponsor?) Howard at Fast Harley til I found a deal I couldn't resist on some Ted Tine FXD-CR shocks. Very pleased with those so far. Some take-off FXDX shocks would be a really good choice since you're interested in lifting the bike. I didn't want mine higher, which is the only reason I didn't go for those.
Old Sep 18, 2008 | 08:11 AM
rhinoWErX's Avatar
rhinoWErX
For a very similar, I am considering a set of these
http://www.arnottairride.com/product...sp?groupId=128
Doesn't require a lot of lean to get the pegs on the ground...
Old Sep 18, 2008 | 09:09 AM
jto667's Avatar
jto667
sucks to be this guy
Old Sep 18, 2008 | 09:12 AM
roberttroll's Avatar
roberttroll
Hmm - When i had mids i never scraped them - I scraped the screw on the bottom of the muffler. The mids would just fold up. Now that i have forwards I do the same thing, except the forwards fold up. If i wanted more cornering performance i would look at getting mufflers that are higher. I cant be the only one who has done this, but then again i did not learn to ride on a cruiser......
Old Sep 18, 2008 | 09:27 AM
SPECIAL ED's Avatar
SPECIAL ED
Taller shocks will help as will cranking up the preload on your stock ones if you haven't tried that yet.Bottom line though is the cornering clearance sucks on these bikes.You might want to consider getting a cheap cafe racer or sport bike if you like going around corners fast.It doesn't have to be anything expensive either a used ninja 250 will run away from a Harley on a curvy road.
Old Sep 18, 2008 | 09:41 AM
kbear's Avatar
kbear
Yep seems to be a common problem but so far as I know no recall for it.
Did my floor board last night looks pretty cool in the dark with all those sparks shooting off. Gotta be careful though don't want to start a forest fire.
Old Sep 18, 2008 | 10:19 AM
christrx's Avatar
christrx
First time I scrapped it kinda freaked me out. I was at Starved Rock in Illinois going through the park coming down a hill with a narrow road and pretty sharp turn and thought I would relive my earlier days (14 years ago I owned a ninja 600) so I went fairly quick and hit the right peg (forward controls) and my heel. I saw a suburban coming toward me but he slowed down and so I went a little wide on the turn. Back in the day my ninja had a center stand and I leaned so far the stand hit a sewer cap that was a little up and kicked up the rear wheel and rotated me a little. That wasn't cool either. So now I know that my dyna is not a lean machine and will be a bit more cautious on turns.
Old Sep 18, 2008 | 10:46 AM
SC-Longhair's Avatar
SC-Longhair
Nothin wrong with scrapin. 'If you ain't draggin...you ain't braggin".
Old Sep 18, 2008 | 10:55 AM
Thunderhorse's Avatar
Thunderhorse
I have scraped both pegs and the rear mufflers. I'm looking at 2-1 exhaust, but would like one that sits higher in the back so as not to mess up the new pipes.
Old Sep 18, 2008 | 11:12 AM
stagolee's Avatar
stagolee
Originally Posted by sick_dyna
...Does anyone else here on this forum have this problem at times? Or am I just leaning way to fare when I make my turns?
Another question I have is, is there any type of shock you can install to in a sense to allow your bike to sit higher...
It's not a "problem", G. If you're scraping and not falling, then you're doing it right.
As for suspension to sit higher, on bikes as heavy as ours you generally want to sit lower. Don't go higher. Trust me here.
