How do you install "solo" seat bolt/screw?
Old Sep 21, 2008 | 12:53 AM
118811fh's Avatar
118811fh
Unhappy How do you install "solo" seat bolt/screw?
Took a long ride today with the 2 up seat.
When I bought my 2001 FXDWG 2 months ago It had the LaPera GEL solo installed
I was able to get my hand in to install screw insert for the 2 up seat hole, but now i want to put the solo seat back on....I can't get my hand back in that far!!!!
I s there a trick to this
Thanks Guys
Old Sep 21, 2008 | 01:15 AM
donr101395's Avatar
donr101395
Put the insert on a long zip tie or something similar then push that through the hole pulling the insert with it. Put the retaining clip on and push the zip tie out to the floor.
Old Sep 21, 2008 | 02:00 AM
jmpancoast's Avatar
jmpancoast
Just to offer a second option, take a piece of string and tie a small nut (or other weighted object small enough to fit through the hole) to the end. Drop it through the hole. Tie the new insert to the string and pull it back through til it seats in the fender.
Old Sep 21, 2008 | 02:32 AM
118811fh's Avatar
118811fh
Thanks guys
I think I'll leave the sleeve in place next time I use
The 2 up seat, I bought a 2nd today!!!
Old Sep 21, 2008 | 05:06 AM
ggibson's Avatar
ggibson
I also use a zip/cable tie, about 12-15" one, takes about 2 minutes to change seats.
Old Sep 21, 2008 | 05:11 AM
tree88's Avatar
tree88
Default Its easy!
feed a long piece of string thru the hole, until you can grab the end of it, tie a knot that the nut wont slip over, and pull the nut into place (slowly so it doesent catch). I had to do this with mine because I only have 3/8"clearance between the tire and the fender, so I fed it up from in front of the tire. hop this helps.
Old Sep 21, 2008 | 06:23 AM
Tele00's Avatar
Tele00
yup.....when you buy a Mustang solo seat they include a zip tie in the bag with the nut/C clip for just that reason.
Old Sep 21, 2008 | 08:01 AM
r00k's Avatar
r00k
I used my boot lace and a knot when I was fresh out of zip ties.
Old Sep 21, 2008 | 10:22 AM
ackman1968's Avatar
ackman1968
I used doubled over scotch tape on my extendable mirror. I do take the one for the two up seat out when going solo just because it rattles and drives me nuts.
Old Sep 21, 2008 | 01:17 PM
118811fh's Avatar
118811fh
thanks again for all the suggestions
Ended up using a 15" piece of weed wacker line
Worked great!!
