Snapped...clutch cable end
Old Oct 7, 2008 | 07:24 PM
SC-Longhair's Avatar
SC-Longhair
Default Snapped...clutch cable end
Tonight, while trying to swap my stock clutch cable for a longer one because of a handlebar swap, I snapped the end of the clutch cable that screws into the 'six speed' clutch cover on the side of the trans.
I'm having some issues getting the broken piece out of the cover.
1) is the end of the clutch cable backwards threaded?
2) Does HD usually out red lok-tite on this fitting? I do see some red gook in there. Either it's lok-tite or a little bit of rust forming.
I've got an ez-out but after 20 min, have not gotten that piece to budge. Any suggestions?
Old Oct 7, 2008 | 07:53 PM
timberwolfz28's Avatar
timberwolfz28
got a micro torch? if it has red loctite, you will need heat to break it loose
Old Oct 7, 2008 | 07:56 PM
SC-Longhair
No, I don't but walmart is still open. I don't know if red lok-tite is present. I'd be afraid I'd damage the chrome cover with the added heat.
Old Oct 7, 2008 | 07:58 PM
timberwolfz28
a micro torch will localize the heat. it doesn't take much really. just a little right around the thread area or on the clutch piece itself.
Old Oct 7, 2008 | 08:02 PM
Livi1215's Avatar
Livi1215
I had this prob last year and posted some pics. The indy hear fixed my trans cover for a 12 pack.
Old Oct 7, 2008 | 08:03 PM
SC-Longhair
So, is that part backwards threaded or do you think, as I, there is lok-tite present?
Here is a pic:
Old Oct 7, 2008 | 08:07 PM
timberwolfz28
I just did my 03 Sunday night and it was threaded normally. But that was a 5-speed. I am uninformed as to whether they changed or not
Old Oct 7, 2008 | 08:30 PM
SC-Longhair
I got it out. I didn't have a micro-torch, but I did have my trusty bic lighter. I heated up the part from the inside, pounded in that ez-out and gripped it with my channel locks. I finally got it to budge. Damn, it was tight. You're right, it was threaded normally.
Old Oct 7, 2008 | 08:31 PM
SC-Longhair
Thanks for the assistance. I suspect the application of heat helped it come loose.
Old Oct 7, 2008 | 08:59 PM
Livi1215's Avatar
Livi1215
Nice job. the ez-out is how they got mine out,that made me feel like an ***....
