Fork oil change - When do I replace?
Old Oct 18, 2008 | 11:34 AM
AdrianVall's Avatar
AdrianVall
Default Fork oil change - When do I replace?
Hey guys,
I believe my service manual says every 20k miles, but I was at Harley in Miami and it said 50k miles? So I'm confused.. what have you guys done? And is this a difficult job for me to do myself or what?
Thanks guys!
Adrian
Old Oct 18, 2008 | 12:24 PM
rounder's Avatar
rounder
thing that sux about your 49mm forks...no drain hole for the fluid...
you should just need the oil. refer to manual on procedure and amount.
Old Oct 18, 2008 | 12:26 PM
RichDIV's Avatar
RichDIV
My dealer did it for me as part of the 10k service. Also had them use SE Heavy instead of oem fluid.
Old Oct 18, 2008 | 08:36 PM
06dynablack's Avatar
06dynablack
47000 miles same oil i spose it should be changed someday lol.yeah bs theres no drain plugs on the bike
Old Oct 18, 2008 | 08:43 PM
Baeseman1's Avatar
Baeseman1
I changed mine at 5,000 miles and could not believe the shat that came out of there. That was some nasty stuff. I have drain plugs, so that made it simple. IMO, you should do it in the near future...
Old Oct 18, 2008 | 08:59 PM
06dynablack
yeah i know i should my other dyna went 35k before the change on that and that did have drain plugs
Old Oct 18, 2008 | 11:59 PM
benwiggin2's Avatar
benwiggin2
never again if you're gonna run the springer...
Old Oct 19, 2008 | 09:24 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default oil change.
As a person who takes forks apart alot, I would suggest changing every 10K miles. When your fork legs are off you may wish to look at a FL lower slider and cut your own drain plug or better still take it to a machine shop. SE fork oil is $3.50/side.
dforeid
Dec 2, 2014 07:36 AM
steelerdude1
Jun 9, 2013 04:53 PM
snookums
Oct 10, 2010 09:30 AM
russl179
Dec 6, 2008 01:27 PM
EdwardK
Nov 30, 2008 01:12 PM
