Too Lean?
Old Oct 27, 2008 | 01:32 PM
dyna07custom's Avatar
dyna07custom
There is an additive in a lot of unlleaded fuel that will make the a little red
Old Oct 27, 2008 | 01:41 PM
Bluesssman's Avatar
Bluesssman
I think your plug look good. How is the engine performing? Any backfiring?
Old Oct 27, 2008 | 04:25 PM
Double00Aught's Avatar
Double00Aught
Originally Posted by 07 dyna man
doesnt look lean looks more like fuel additives like octane booster or even the brand of gas, different brands have different colored dye in them
Ok that makes sense then. I used a bottle of octane booster a few fill ups ago.
Old Oct 27, 2008 | 04:27 PM
Double00Aught
Nope it's running fine. I just got the urge to pull the plugs last night, and the color threw me so thought who better to ask than the pros here.
Old Oct 27, 2008 | 04:50 PM
07 dyna man's Avatar
07 dyna man
Default to lean
do what i do,find a place that sells race fuel , i run 1gal of 100 octane unleaded cam 2 to 4 gal of high test, it smooths the bike out and runs alot better pulls a little harder, and stops the occasional ping
Old Oct 27, 2008 | 06:56 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on fuel additives, usually the center electrode should be ash white to tan, no black fluffiness, black wetness, just dry tan or lighter. Change plugs then run some premium gas from a name brand station, check your plugs after a couple hundred miles. Don't use E85 fuel it's not good for the rubber in your fuel system and theECM can't adjust for it. 10% ethanol is the highest rating ethanol you can use in the engines from Harley.
Old Oct 27, 2008 | 10:18 PM
rounder's Avatar
rounder
I was wondering how one goes about getting their spark plugs decorated for halloween....
clyles
Mar 28, 2015 07:06 PM
aces&8s
EVO
Jul 26, 2014 10:12 PM
RHillbilly
Jun 2, 2012 07:20 PM
2011Iron883
Mar 27, 2011 11:04 AM
Stomper-63
Aug 30, 2010 12:11 PM
